GM 1.4 LUV/LUJ
If I recall from when I looked at them, because of the placement in the head they are ground opposite each other.
These guys are selling a cam for the intake and recommending that you install the stock intake cam (more lift and duration) on the exhaust side. Am I right that this could be trouble?
https://zzperformance.com/collections/s ... mance-cams
You can see in this pic the inverse radii are opposite
Are these cams opposite?
Re: Are these cams opposite?
Isn't it common for Miata people to swap the intake cam for a bigger exhaust cam? IIRC, they either count the number of teeth when installing (the timing marks no longer line up), or they drill a hole in the gear with the proper offset. I haven't looked at how a Cruze is set up, but I doubt it would be much different.
The Miata has a bucket style setup so the lobes are symmetrical. The GM motor has roller followers.
I just wondered, is what I think I’m seeing correct, and if so, what happens when you have the inverse radius on the closing ramp?
I/PS land speed record holder
Either this forum is dead or I asked the wrong question.
I had the chance to look at a set of these cams and they are definitely ground opposite each other.
So I ask, what do you think the effect will be of running the intake cam on the exhaust with the inverse radius on the wrong side?
- New Member
Hi mate, I’m no expert, I’ve been wasting a lot of time on this stuff. This place is the best but Dohc, sohc, is very limited. I would suggest a pm to Cam King and give him time to reply. Very busy guy.
From what you’ve posted the inlet grind looks a bit bigger but with some softness. It may work for ok. But without some serious valve motion data who knows.
- New Member
