GM 396 cylinder notches
ProPower engines
Post by ProPower engines »
Hey guys
Is there any way to tell by casting numbers which blocks were really notched for bigger valves.
I am in the process of a build on an early 66 or 67 396 and it does not have notches for s 2.250 valve.
But customer is concerned at this point about a numbers block I am starting with may be not correct.
The block 2 bolt main block casting number is 3855961 if that helps.
Personally I do not find anything in any GM literature about specific blocks that were notched for the bigger valves
Any insight here will be greatly appreciated before I start milling the bores.
Dave
dannobee
Re: GM 396 cylinder notches
Post by dannobee »
What is the three letter code on the deck? Is it still there? I'd trust that more (assuming it's still there and not altered) than the casting number.
SchmidtMotorWorks
Post by SchmidtMotorWorks »
I would be more interested in the chamber match and the measured clearance.
ProPower engines
dannobee wrote: Thu Feb 18, 2021 9:34 pm What is the three letter code on the deck? Is it still there? I'd trust that more (assuming it's still there and not altered) than the casting number.
I forgot about that. Too much dodge and ford stuff lately :oops:
I will post it tomorrow.
HDBD
Post by HDBD »
Often times the casting number does not tell the whole story. For example #512 427 two bolt blocks were used in low HP 69 Impala all the way up to the COPO 425hp 4 bolt blocks with the larger oil pressure outlet and valve reliefs in the cylinders. The machining package for the application and the pad stamp code tells the rest of the story.
novadude
Post by novadude »
I thought the small bore 396 all had notches in the bores.
Post by F-BIRD'88 »
If using 2.25" valves the oem cylinder notch will need radiusing to match.
BillK
Post by BillK »
ProPower engines wrote: Thu Feb 18, 2021 9:10 pm notches for s 2.250 valve.
Dave,
Dont know how to tell which blocks were notched but I dont think they ever had a 2.250" valve. 2.190" was the largest as far as I know.
HDBD
Post by HDBD »
novadude wrote: Fri Feb 19, 2021 9:33 am I thought the small bore 396 all had notches in the bores.
I think this is correct.
Post by F-BIRD'88 »
If I wanted to use a 2.25" valve I would swap the 396 block for a 427-454 4.251"++ bore...block The result will be better in EVERY WAY that matters.
FloydODB
Post by FloydODB »
Just tore apart a 454, 4 bolt 445 casting ckj107443 stamp with notches. RR marine engine.
Daniel Brown
Accurate Engine Rebuilding
(269)930-1962
rustbucket79
Post by rustbucket79 »
Were the big valve (375 horse) blocks not all 4 bolt?
swampbuggy
Post by swampbuggy »
I would give a person odds that they were all 4-Bolt main caps, Mark H.
swampbuggy
Addendum to the above, "All" meaning ( High Performance ) / highest power rated engines in each cubic inch size examples= 302/290....327/375...350/370...396/375...396/425 only offered in 1965 i do believe...427/435...454/460 . I know that there were other engines with slightly less power that were also 4-Bolt blocks. Mark H.
HDBD
Post by HDBD »
They had 4 bolt main caps, yes but the lower horsepower versions, sometimes with the same casting numbers had a smaller oil pressure outlet and 2 bolt mains.
