097 sbc cam
097 sbc cam
Has anyone tried a gm 097 cam with rocker ratio of 1.7 to 1.8 ? I have one I installed in a 350 and wanted more lift and it's a basically free or next to nothing build for the fun to see what it will do.
Re: 097 sbc cam
Its more fun to just change the camshaft for a funner cam.
Lots of choices for fun/$$$...effect.
Re: 097 sbc cam
Years ago, we used to have that lobe ground on a 292 Chevy 6 cylinder camshaft core.
They have 1.74/1 rocker arms and it worked great on the short oval tracks.
Re: 097 sbc cam
With a 1.8 ratio it should be about .480 lift . Z28 springs should work fine or factory springs possibly.
Re: 097 sbc cam
Yiu can get stock diameter ".550" lift racing springs for the same money.. Much better. Summit, pioneer ,Elgin, Howards, Isky etc
1.7 or 1.8 sbc rockers will cost more than a new cam that has more lift anyway. You might see 10 horse but will see a lot more with a new cam and 1.5's..
If yiu don't have these 1.8 rockers sitting there to try out you are just wasting your time and money..
Re: 097 sbc cam
F-bird, you're being a Debbie Downer. The OP specifically said "097 cam" and "for the fun to see what it will do." I've had a lot of fun with an 097 cam. Spent the afternoon helping swap one into a '56 265 and the evening at the drive-in with a junior high sweetheart (I think the movie was "The Blob", Steve McQueen's first staring role). To get in the drive-in for free my date and I hid in the trunk. Cruising the gut after that with the rockers doing the castanets thing. I recall the cam, lifters and gaskets were less than $30. That was fun. It would be fun to do it again.
Summit has these 1.6 ratio for only $62.99
https://www.summitracing.com/parts/sum- ... gL2BfD_BwE
Re: 097 sbc cam
Is it really "FUN" to spend money on a set of high ratio rockers, and all the time it takes to set everything up, just to find out you are making less power everywhere, then what you would have made with some generic off the shelf cam ?
That doesn't sound like "FUN" to me.
Re: 097 sbc cam
I guess everybody missed the OP saying the 097 and lifters is already in the engine and all he wondered about is changing rocker ratio.
OP, it may be to please these folks you better just do the LS swap thing or change heads or turbos or something equally profound. Nitrous and new pistons. A lot of new pistons.
Re: 097 sbc cam
Is it really all that easy to put 1.7 or 1.8 rockers on a SBC?
Especially if it has factory old school heads.
Re: 097 sbc cam
That's a good question about how hard it is to put 1.8 rockers on a gen 1. I have the rocker for free to try . I do have a 6.0 ls but really don't want to do that to my camaro. I think the gen 1 is more relaxing for me to work on. I work on new stuff all day . I do have a new technology cam and lifters but am saving that stuff for my 406 I'm building .My machinest dad passed away so I'm giving him time to catch up on stuff and am messing with this 350 for now .
Re: 097 sbc cam
A 1.6 rocker on factory Gen 1 heads can lead to pushrod rubbing on the casting, you’re definitely machining to fit higher than that.
Re: 097 sbc cam
Over the years, I have used a "Louis Tool" many times ...rustbucket79 wrote: ↑Sun Feb 21, 2021 10:41 pm A 1.6 rocker on factory Gen 1 heads can lead to pushrod rubbing on the casting, you’re definitely machining to fit higher than that.
Re: 097 sbc cam
"rockers doing the castanets" In another lifetime I had an L79 327 in my 60 Bel Air. I was riding in my friends Mach 1 along side my bother in the Chevy. My bother dropped down a couple of gears and wound the 327 out to about 7000 with us along side keeping up. The sound of the 327 screaming at high rpm was pure music.
Re: 097 sbc cam
No. This is something we did multiple times on limited circle track classes.
It's about impossible to get the geometry right with 1.8 rockers on a GM head. In most cases, the geometry is so far out of whack, the rocker ratio right off the base circle is over 2:1. This causes all kinds of issues.
Re: 097 sbc cam
1.8 on a Gen 1 sbc ....
1.7 you either need a offset trunion or your moving the stud/ shaft setup. Push rod needs some room also. Couldn't imagine a 1.8
If it was something that made money, I'd roll the valve angles first so not to get caught.
