+1pcnsd wrote: ↑Fri Feb 26, 2021 10:20 pm I toured SpaceX in LA 5+ years back as a guest. This is the same process they used to build their directional thrust nozzles. I was impressed with the print technology at the time but questioned the time/cost factor. They said that the provided flexibility for their limited production needs was a good fit. I think these things will only improve as time progresses.
For specialty volumes that are far below the profit volume for a casting, it’s great.
Casting is scary, the volume needed to make a profit is scary and you better hope you sell that many before it becomes redundant. 3d printing helps fix that, and allows you the geometries (and even more freedom in ways) that only a casting can give you.
