Air fuel with boost
Air fuel with boost
Is 10.5 a/f too rich for a boosted application sbf 10:1 comp 121 octane 12 psi p1sc procharger 15 degrees total if not what should my target a/f be at
Re: Air fuel with boost
If you have great knock suppression you can run 12:1.
If not you may need 9:1.
The extra fuel "overfueling" helps some, up to a point.
Beyond that point, it adds to the destructive force and heat of detonation/ (leading to) preigintion.
Intercooling is more effective. (air to air) (water to air)
Water Methanol injection is more effective
both are more powerfull too.
