Sonic testing
Sonic testing
Do you all know if you do sonic test on a block are cylinder that has a sleeve in it does the tester pick up both the original cylinders thickness and the thickness of the sleeve are just the original cylinder thickness only.
- New Member
Re: Sonic testing
So the only way to tell how much of the original cylinder was left would be to sonic the from the water jacket side.Thanks
Re: Sonic testing
It'll be tough or maybe impossible to get a reading on a convex rough casting surface.
"do it right or do it right away"
http://www.motionmachineinc.com/
https://www.youtube.com/watch?v=ZgIZbveknDs
