how to remove fuel hoops on bbc heads
badbug3
Post by badbug3 »
ways to remove fuel hoops on bbc
mag2555
Re: how to remove fuel hoops on bbc heads
Post by mag2555 »
I am not familiar with your terminology, what is that relating to about or in the heads?
millerperformance
Post by millerperformance »
use a thin piece of thin metal with a .080 slit in it and tig it to the wire!
Tuner
Post by Tuner »
mag2555 wrote: Wed Apr 21, 2021 3:01 pm I am not familiar with your terminology, what is that relating to about or in the heads?
https://www.enginelabs.com/engine-tech/ ... ire-rings/
Bryan Maloney
Post by Bryan Maloney »
I just had to remove a set a week ago.
After trying to fuse a section of filler rod to the hoops, I ended up just building up a ball of weld about .080 tall on each hoop. Pinched them with vise-grips, and wiggled them up and partially out of the groove. Use a thin gasket scraper to help finish prying them upwards as you go around.
The hoops actually came out a lot easier than I had anticipated.
Post by MadBill »
Tuner wrote: Wed Apr 21, 2021 7:31 pm...
Ah! What some people call O-rings! #-o
