4779 carb replacement
I have an old 4779 carb modified by Brad Urban in 1984 with 4 corner idle and holes drilled in the throttle blades it has the stock 4779 metering blocks with no removable air bleeds and with a new cam and intake set up it runs rich at idle. I am looking to replace it with something new and I am looking for something bigger in cfm like 850-1050 . motor is a 427 SBC , 4.125 x 4 inch good heads and intake Stahl step headers 263-268 solid roller. Who makes a carb that I can bolt on and be fairly close and can tweak from there?
Re: 4779 carb replacement
I would start with a Quick Fuel 850 they have removable air bleeds as well as in the metering blocks they use emulsion jets that can be changed out as well.
They are way easier then trying to tune an older Holley with out removable bleeds etc
I would modify the 4777 for removable bleeds, idle jet, PVCR, etc. An old 4777 is a tough act to follow for a lot of "modern" carburetors.
You might just need a new carb kit and some wire in the idle jets to lean it a bit.
I ran an Holley 830Hp last year that worked pretty well after getting the jetting right. Idles well and car pulls like crazy.
Gday,
Put a kit in it, wires in the idle jets as mentioned work fine,
I know which carb I would rather have.
Those old ones are awesome, plenty big enough and work properly
Cheers
Cheers
Is this a race vehicle or street driven vehicle ?amc fan wrote: ↑Wed Apr 28, 2021 1:42 pm I have an old 4779 carb modified by Brad Urban in 1984 with 4 corner idle and holes drilled in the throttle blades it has the stock 4779 metering blocks with no removable air bleeds and with a new cam and intake set up it runs rich at idle. I am looking to replace it with something new and I am looking for something bigger in cfm like 850-1050 . motor is a 427 SBC , 4.125 x 4 inch good heads and intake Stahl step headers 263-268 solid roller. Who makes a carb that I can bolt on and be fairly close and can tweak from there?
Walter... it is going to be a bracket race car mostly , but will be driven to cruise nights. It is an 86 Hurst Olds. The carb that was first tried on the car was a ( Proform 850 ) it fouled the plugs quickly and it had to be idleing at 1300-1500 to stay running ,we swapped it with the 4779 from my 68 AMX ...which idles rich, but so far it is not fouling the plugs , I need the Holley for my car so He has to fix the Proform or get a better carb.
So then why not just send the carb to a specialist and get the fuel curves corrected based on the application.amc fan wrote: ↑Wed Apr 28, 2021 9:22 pm Walter... it is going to be a bracket race car mostly , but will be driven to cruise nights. It is an 86 Hurst Olds. The carb that was first tried on the car was a ( Proform 850 ) it fouled the plugs quickly and it had to be idleing at 1300-1500 to stay running ,we swapped it with the 4779 from my 68 AMX ...which idles rich, but so far it is not fouling the plugs , I need the Holley for my car so He has to fix the Proform or get a better carb.
They can then remove the fixed air bleeds and install the more current removable bleeds for faster tuning of the idle issues it has now. The proform carbs are hit and miss from what I have seen and heard from guys that tried them because they are a cheap version of what you really want and need..................a carb that works and preforms well.
Or just get a quick fuel as they come with all the current fuel curves and it would be the same or less then sending the other carb out to a shop that just may say its junk and can't be fixed.
Even a used carb can easily be brought back to life with a kit and an hour of your time and a used QF can be had for much less then a new carb and way better then a 40 year old carb that has been screwed with.
JMO
I would call AED and see what they say. They might be able to make yours work. If not they will sell you what you need. Great guys to deal with and great carburetors.
https://www.aedperformance.com/
If you have the time ... I would send that ProForm carb to a reputable "modifier" and give them time to fix it.amc fan wrote: ↑Wed Apr 28, 2021 9:22 pm Walter... it is going to be a bracket race car mostly , but will be driven to cruise nights. It is an 86 Hurst Olds. The carb that was first tried on the car was a ( Proform 850 ) it fouled the plugs quickly and it had to be idleing at 1300-1500 to stay running ,we swapped it with the 4779 from my 68 AMX ...which idles rich, but so far it is not fouling the plugs , I need the Holley for my car so He has to fix the Proform or get a better carb.
If you need to get one right now ... I have had good luck with a Quick Fuel Q-950; (if it is still available).
Thanks everyone for the suggestions and help. I found some videos on you tube from a guy Randy who says he has 40 years of tuning and modifying carbs, and he shows how to modify idle bleeds on old Holley carbs. I drilled .070 holes in all four butterflies and I measured the IFR on the Proform metering block and .034 pin slid in and out with a slight drag. I will try the carb with just the holes in the throttle blades first, and if it is still rich I will try going down .003 at a time on the IFR and watch what happens.
Before you change the idle jet size try a larger idle air bleed. What size is the IAB now?amc fan wrote: ↑Sat May 01, 2021 2:27 pm Thanks everyone for the suggestions and help. I found some videos on you tube from a guy Randy who says he has 40 years of tuning and modifying carbs, and he shows how to modify idle bleeds on old Holley carbs. I drilled .070 holes in all four butterflies and I measured the IFR on the Proform metering block and .034 pin slid in and out with a slight drag. I will try the carb with just the holes in the throttle blades first, and if it is still rich I will try going down .003 at a time on the IFR and watch what happens.
Tuner
I do not have gauge pins over .060 ,so I used a number 51 number drill that measured .070. So the size of IAB would be .070
Tuner
