titanium valves
Bumps440
titanium valves
Post by Bumps440 »
Is there an RPM where you should seriously consider using Titanium valves. 150 gm intake valve going over 8000rpm should I be looking Titanium?
TI valve I am considering is 94 gm I know it would be much easier to control that than a 150 gr valve.
Opinions wanted ....
KnightEngines
Re: titanium valves
Post by KnightEngines »
Yeah, you want Ti.
Not just easier to control, also reduces stress on the entire valve train, springs, rockers, lifters will all last longer.
Big up front cost, but they'll pay for themselves over time.
steve316
Re: titanium valves
Post by steve316 »
On a 8500 rpm SBC the springs lasted 3 times as long with 20 lbs less spring pressure
1980RS
Re: titanium valves
Post by 1980RS »
Is it true that you need lash caps on Ti valves?
zums
Re: titanium valves
Post by zums »
1980RS wrote: Mon May 03, 2021 7:51 pm Is it true that you need lash caps on Ti valves?
Depends on the valve, if it has a hardened insert no, if not yes, the latter with a cap is a better set up and less weight
Tom
