Deck clearance?
Alaskaracer
Re: Deck clearance?
Post by Alaskaracer »
I think I'd listen to Steve. He builds some of the most powerful and fastest supercharged/turbocharged engines in the country.....He knows what he's talking about.....
Mark Goulette
Authorized Amsoil Retailer
Super_Stock
Re: Deck clearance?
Post by Super_Stock »
I listened .... No clearance or lots of clearance.. I guess anything in between is OK as well... LOL..
I've used tight squish to get rid of death rattles, not induce them.
Maybe it's a different story on the old diesel air pump and hair drier stuff..
englertracing
Re: Deck clearance?
Post by englertracing »
Super_Stock wrote: Mon May 17, 2021 5:48 pm
stealth wrote: Mon May 17, 2021 12:08 pm I agree with this...:
https://www.youtube.com/watch?v=lr86J9g0PWA
What? Drawing on your cylinder head?
So you either have virtually no gap between the head and piston top or you enlarge the gap so the flame front can get in there to stop pinging?
I don't know, but I think that's a real laugh...
Maybe if he showed a head that had the chamber "laid back" as he says, instead of the felt tip diagram, then it may make a little more sense, but he's sort of describing an open chamber style head to me..
Might as well run a small dish in the piston.
It's something that's done on turbo and nitrous stuff well into quadruple digit horsepower levels.
Super_Stock
Re: Deck clearance?
Yeah, it's old news, doing all that chamber magic went way with a better piston design..
stealth
Re: Deck clearance?
Post by stealth »
I guess... Keep laughing...
this guy seems to agree too....(he even marks up heads too)
https://youtu.be/YOSF32VgTt4
Chris_Hamilton
Re: Deck clearance?
Post by Chris_Hamilton »
Didn't Steve Morris mention in that video something about cutting a trough in the head. To someone who is relatively ignorant like me that sounds like the Singh grooves that many here seemed skeptical about.
And wasn't the OP talking about a NA setup? Are boosted/turbo chambers all that relevant?
Super_Stock
Re: Deck clearance?
Chris_Hamilton wrote: Tue May 18, 2021 11:47 am Didn't Steve Morris mention in that video something about cutting a trough in the head. To someone who is relatively ignorant like me that sounds like the Singh grooves that many here seemed skeptical about.
Yes, it's not relevant.
Stealth, the only reason I'm having a chuckle is because he's simply describing creating an open chamber..
Ah yes, the "Singh grooves".. Maybe a "spiral" ground into the squish pad will be the next big thing?
You heard it first here fellas. I'll call it the "Cosmic Spiral". Feel free to test it..
And yes, it's not relevant either.
Alaskaracer
Re: Deck clearance?
Super_Stock wrote: Tue May 18, 2021 2:59 am Yeah, it's old news, doing all that chamber magic went way with a better piston design..
Not when it comes to big nitrous engines. They soften the chambers on pretty much every build. How much of a cut and angle of cut is determined by chamber shape and amount of nitrous they will spray. My cylinder head guy does ALL of Pat Musi's stuff....if you think they aren't playing with the chambers and just using a "better piston design", you're somewhere out in left field, WAY past the fence......
Mark Goulette
Super_Stock
Re: Deck clearance?
Coloradoracer wrote: Tue May 18, 2021 10:38 pm
I'm sure people play with chambers all the time, in conjunction with piston design..
houser45
Re: Deck clearance?
Post by houser45 »
.035” to .040”
408 Nova
Re: Deck clearance?
Post by 408 Nova »
Well everybody, I'm going with .040", as close as I can get anyways.
Thanks everyone for your recommendations and tech advice.
Super_Stock
Re: Deck clearance?
Cheers..
GettyUp
Re: Deck clearance?
Post by GettyUp »
Any comments about the clearance amounts and RPM use discussed in this video? https://youtu.be/rBZCnG1HwDM?t=2381
Re: Deck clearance?
It is widely accepted that (at least for NA apps) zero dynamic squish/quench is ideal, but unless one is prepared to creep up on it maybe five thous at a time, better to leave ~0.040" for steel rods and 0.060" for aluminum. Obviously, other factors apply such as RPM, component design and weight, piston rock at operating temperature, aluminum block expansion, etc.
