Pump gas 421 SBC HP
- mt-engines
Re: Pump gas 421 SBC HP
Final graph
I love these small cam builds. Mt, any porting work? Thanks, Charlie
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
472 observed HP @ 900 feet elevation, 29.10 baro, derived from the first sheet posted.
With only 0.0460" lift, the cam specs are surely 'advertised' rather than @ 0.050", so how can it possibly be still gaining power at over 6500 RPM?
- mt-engines
- mt-engines
He bought my 80496-1 950 dyno carb. It picked up everywhere and allowed it to spin higher than planned.
- mt-engines
I get compression at 10.3:1. I'm curious about the cam. With such small numbers you clearly have done your homework to achieve the HP numbers posted.
This is not a Racing Engine, i am quite sure the .460" is at the valve and the Duration numbers are "Not" @ .050" lifter rise. I believe what we are seeing here is an example of what a great Carb, Intake, and well prepped cylinder heads can do in spite of a small numbers Camshaft. Mark H.
Remember, the more efficient the intake tract is from the carb booster to the bottom side of the valve seat, the less camshaft ( especially ) duration will be needed. I will say, if the net valve lift is " only " .460". that is a surprisingly small amount. Mark H.
594 hp @ 6700 worth?swampbuggy wrote: ↑Sun Jun 06, 2021 11:01 am Remember, the more efficient the intake tract is from the carb booster to the bottom side of the valve seat, the less camshaft ( especially ) duration will be needed. I will say, if the net valve lift is " only " .460". that is a surprisingly small amount. Mark H.
Jim
Where is the "ENGINE TECH"..........you post basic spec build and will not answer people with genuine questions........
I thought we are on here to learn and grow.
