Break in oil magic
RDY4WAR
Re: Break in oil magic
Post by RDY4WAR »
David Redszus wrote: Wed Jun 16, 2021 12:27 am Just curious.
What specifically do we expect a "break-in oil" to do that a normal motor oil does not do?
By "specifically" I mean what is the expected effect of the oil on each part of the engine: rings, valves, cams,
bearings, pumps, etc.?
Does the time period available for break-in make a difference as well?
The main thing with the break-in oil is additive response. There's 3 ways that ZDDP becomes active: heat, pressure, and friction. On initial startup, you have neither heat nor high pressure so you need friction. The right type of ZDDP (short-chained, secondary alkyl), that'll be more reactive at low temperatures, helps a lot as well. Common non-breakin oils, including racing oils, don't have as good of reactivity at low temperatures, mostly due to the type of ZDDP used (blended 70/30 primary/secondary alkyl), the amount of detergents used, and interference from friction modifiers and extreme pressure additives.
The intent is to get an anti-wear tribofilm established as quick as possible to minimize wear during break-in as much as possible. The rings transition through all 3 lubrication regimes, experiencing mixed and boundary lubrication at TDC and BDC and ~20 degrees of rotation each direction from TDC and BDC. ZDDP is active only in mixed and boundary lubrication so getting that AW film established as quick as possible will help keep down ring wear during break-in and help with sealing. The bearings operate solely in full hydrodynamic lubrication so there's no effect there. The base oil is more important there. The valvetrain is the same with wanting that AW film on the lobes, lifters, pushrod tips, rocker tips, etc...
A common API oil like Rotella or "racing" oil like VR1 will still allow the engine to break-in, but the break-in will take longer and accrue more wear in the process.
David Redszus
Post by David Redszus »
RDY4WAR wrote: Wed Jun 16, 2021 12:38 pm
Thanks. A great answer to a topic that is often filled with mystery and folklore.
n2omike
Post by n2omike »
I posted this a year or so ago. The videos are from Lake Speed at Total Seal Pistons rings regarding Break-in oils.
Break-in Procedure
https://www.youtube.com/watch?v=6XEYJrSqHtw
Break-in Oils/Science
https://www.youtube.com/watch?v=teDgJgPeeeU
Oil analysis on 22 different break-in oils, and oils commonly used for break-in.
https://static1.squarespace.com/static/ ... eport1.pdf
From what I can see Lucas 30W break-in oil is a steal at around $31 for a 5 quart jug.
Driven is a really good brand. I believe it use to be Joe Gibbs.
Some break-in oils do not match what Total Seal recommends.
Link to that post:
viewtopic.php?t=61152
autogear
Post by autogear »
Lake Speed Jr was the certified lube specialist for "Joe Gibbs" Driven Racing Oil. I think, at one time he was at least part owner.
He definitely knows his stuff :)
CamKing
Post by CamKing »
autogear wrote: Thu Jun 17, 2021 3:44 pm Lake Speed Jr was the certified lube specialist for "Joe Gibbs" Driven Racing Oil. I think, at one time he was at least part owner.
He was a salesman for Gibbs. Maybe Joe certified him :lol:
When I asked him technical questions about the oil he was trying to sell me, he had to ask an engineer, and get back to me.
lefty o
Post by lefty o »
certified lube specialist is the kid that either overfills your crankcase or puts no oil in it at jiffy lube type places! :shock:
autogear
Post by autogear »
CamKing wrote: Thu Jun 17, 2021 3:46 pm
lets be fair; gearbox oil is pretty low on the curve compared to what you are working with
As long as the film strength is application correct? if its too slippery, add friction modifier, if that doesn't work - use something else :-D
At least we would get answers; the guys at Brad Penn after the buy out? Wouldnt even say if their oil was safe for bronze or not, but sent me a nice polo shirt :D
BradH
Post by BradH »
I believe he states he's a Certified Tribologist or Certified Lubrication Specialist. Guess I could be too, if I studied for the 150 multiple-choice question exam and scored at least 70% correct. Of course, that could also mean I'd be wrong up to 30% of the time, as well.
https://www.stle.org/files/Professional ... 8d18add79c
https://www.stle.org/files/Professional ... 80d8cd6455
Oh, says I need "three years of experience working in the field of lubrication." That certainly leaves a lot of room for interpretation...
I'm sure L Speed Jr knows more about the subject area than I do. However, I'm really jaded over people using certifications as proof of expertise when some of the worst Project Managers I've ever worked with came in waiving their CPMs as if everyone could ASSume they actually knew what they were doing...
Roundybout
Post by Roundybout »
Is the protective layer created sacrificial in that it needs to be replenished? Can a different type of additive (ZDDP) now be used that would normally take too long during a normal break-in procedure?
The first start is critical in that a quality oil with the proper chemistry goes a long way. Then the oils with the proper chemistry for the conditions for a long durable life.
BradH
Post by BradH »
PSA wrote: Sat Jun 12, 2021 4:42 am
BradH wrote: Sat Jun 12, 2021 9:09 am Would the last 2 posters be more specific about which brand(s) of break-in oil they are referring to? I've come across VOAs for a few different break-in oils and the variations between them are significant with respect to amounts of zinc & phosphorus additives.
I can post a VOA of Driven B30 later today.
Ever find that VOA? I've got 7 of these on the shelf and would like to know more about the product. Thx
dannobee
Post by dannobee »
n2omike wrote: Thu Jun 17, 2021 9:28 am From what I can see Lucas 30W break-in oil is a steal at around $31 for a 5 quart jug.
That's' my feeling on a lot of their stuff. Years ago we got a Lucas sponsorship and with it came free product. At first I was like, "whatever, put it with the rest of the crap." After running out of some of our usual stuff, I reluctantly started trying it, and I was really impressed with almost everything they sold. To this day I won't use anything but Lucas X-Tra Heavy Duty green wheel bearing grease on circle track cars.
bob460
Post by bob460 »
Anyone use/tried the 10 10 10 break in method?
https://www.youtube.com/watch?v=b2LzSz9W1Sk
MELWAY
Post by MELWAY »
bob460 wrote: Fri Jun 18, 2021 12:59 am Anyone use/tried the 10 10 10 break in method?
I have mostly done that on flat tappet cam break in
I have found Driven BR oil to be great on flat tappet break in
Upon inspecting lifters after 30min break ins then install heavy springs
PSA
Post by PSA »
BradH wrote: Thu Jun 17, 2021 4:36 pm
You must have cut and pasted wrong, it was the other guy that had something to share. :)
PSA
Post by PSA »
I'm not sure what would be gained as you typically want some temperature during break-in, but if they have tested it and found good results I wouldn't doubt their findings either.
The time I was involved in tests like that it was more about the rings (not flat tappet cam), and it was more of a problem of getting the heat up fast enough to put load on the engine. The time window wasn't very big to get an ideal break-in with the combination of materials and machining that was used.
