difference between a 3310 and 4779 primary metering blocks.
rfoll
Post by rfoll »
I would think they would be interchangeable, but my research says otherwise. What's the diff? The venturi sizes are the same.
1980RS
Re: difference between a 3310 and 4779 primary metering blocks.
Post by 1980RS »
rfoll wrote: Fri Jun 11, 2021 7:53 pm I would think they would be interchangeable, but my research says otherwise. What's the diff? The venturi sizes are the same.
I have used them on both the 3310 and 4779 and interchange them all the time with no problems. The sec ventui's on the early 3310's are bigger until the -4 or -5 then they measured the same.
ozyfordman
Post by ozyfordman »
I can’t verify it but I believe that the PVRCs are larger on the vacuum secondary models over the DPs I’m sure I read it in a book long ago.
jmarkaudio
Post by jmarkaudio »
Thread both the idle feeds and PVCR's and it won't matter.
Mark Whitener
www.racingfuelsystems.com
____
