Octane rating vs CR
Re: Octane rating vs CR
Way too many variables to even make a half assed guess IMO.
Many modern engines run 12:1 or a little higher on 87 just fine.
Don't know about dynamic, but my 511 has 12.5:1 static and runs safely with 100 octane. 36* total timing. 270@50 solid FT.
- mt-engines
The criteria here is 2V wedge and heart shaped chambers, both aluminum and cast iron. Old school, if you will, not direct injection.
A safe guild line, in a loaded engine, with a .040 - .060 squish.
80 deg 800 ft elev.
80 deg 800 ft elev.
That 270°cam with the right timing events makes that happen, you sure would not want to do that with 12:1 and a 230°@ .050 engine would rattle itself to death.
Well, if you believe what's printed in the car magazines of old, about 20 years ago Super Chevy put together a Vortec headed 355.
8.75:1 SCR and used Comp's XE268H cam (I believe on a 108 ICL).
Quench at .044".
87 octane fuel (from who's pump I can't say other than being California based) and netted peak TQ of 427 at 4000 and peak HP of 390 at 6000 on the magazine dyno.
DCR works out to 7.2:1.
Make of it what you will.
Quench at .044".
Kevin
I live in Oregon and we have both 87 & 92 oct, with ethenal in the winter months. But, to any that may post, assume it's your local pump, that you pull up to, when you need gas.
I remember the old version of PipeMax spitting out an actual fuel octane rating recommendation...
I don't have the newest version so can't comment on it.
DCR, squish / quench, IAT, chamber design, lots and lots of variables.
Many smart folks on here don't even want to make a call with DCR #'s... should possibly give you pause on accepting a simple answer to a complicated question.
David doesn't even want to make a call with RON/MON ratings of pump gas included.
And 160F dyno water, probably...skinny z wrote: ↑Mon Jun 14, 2021 3:19 pm Well, if you believe what's printed in the car magazines of old, about 20 years ago Super Chevy put together a Vortec headed 355.
Quench at .044".
Even the # of variables is variable in these tests.
Undoubtedly.NewbVetteGuy wrote: ↑Mon Jun 14, 2021 5:58 pm And 160F dyno water, probably...
Like I was saying...
Kevin
At what temperature??? That has very much to do with, what will work.
Depends on the load on the engine as well, in my opinion. Is it a 500 cube motor pulling a 3000 lb vehicle with 4.11 gears or a 250 cube motor pulling a 4000 lb vehicle with 2.75 gears? One might detonate and one might not, with the exact same DCR and octane.
JMO,
paul
JMO,
paul
Randy and Paul. Temp and Elev are as above. Loaded is loaded, no matter the weight. Consider it a steady dyno pull at 160 deg engine temp. The 80 deg is assuming air intake, out side the engine compartment.
I know by application, there are things that work. Such as 6.8 DC but, I would like a upper end number to build a engine to.
Will 7.5 do it, in those exacting numbers, supplied above?
