Audie Flow Pro
learner1
Audie Flow Pro
Post by learner1 »
Anyone using the Flow Pro? It doesn't seem to be communicating with the sensor module. Not sure if i'm just missing something on the setup or if it's my computer.The sensor module reads the depression and temperature but nothing else and the software readings on the monitor are all blank.
HDBD
Re: Audie Flow Pro
Post by HDBD »
You need to be sure the port is selected properly in the program to assure the program communicates with the module. The newer ones are usb, older used rs232
learner1
Re: Audie Flow Pro
Post by learner1 »
Will your sensor module display cfm without the software open?
HDBD
Re: Audie Flow Pro
Post by HDBD »
Yes and depression.
learner1
Re: Audie Flow Pro
Post by learner1 »
I suspect i have more than one issue then.
HDBD
Re: Audie Flow Pro
Post by HDBD »
Audie and John are both very good at helping, give them a call.
