What are peoples opinions on replacing the heavy factory front pulley with a lighter weight , smaller billet aluminium unit? Flat 4's are supposed to be inherently balanced, but this is different to frequency vibrations caused at certain rpm/load. Could a solid, lighter pulley destroy bearings on a flat engine at high rpm?
There seems to be some debate on certain sites about this, but I've not read anything conclusive.
Harmonic balancer's and Subaru flat 4's
Re: Harmonic balancer's and Subaru flat 4's
for me, there is no way in heck i would take a dampener off and replace it with just an aluminum pulley. ever notice how much that flat 4 shakes/vibrates. dampeners absorb harmonics, you just make things worse without one. a flat 6 is much more smooth, and id still not run just a pulley. if you want to remove weight to gain performance, lose the weight with different wheels, different brake rotors, or a carbon fiber driveshaft. these give you a benefit without the negative.
If an H4 is balanced, then an H6 must be better, right? Porsche had problems with the GT3's breaking crankshafts when, you guessed it, the factory went to a lighter weight RS front crank pulley and did away with the harmonic balancer.
Only directly opposing cylinders with male/female rods do not have rocking couple.
I DAILY DRIVE A 2000 LEGACY AND IT HAS A PERRIN PULLEY ON IT. I'VE PUT 100K ON IT AND ONLY THING I'VE HAD TO DO IS THE HEAD GASKETS. LOL CAR HAS 279,000. I HAVE NO CLUE HOW LONG THAT PULLEY HAD BEEN ON IT BEFORE I GOT IT
