Piston guided rods
Re: Piston guided rods
If the rod placement and side clearance have a chance to side load in any way, it can; especially if the crankshaft gets shorter dimensionally through distortion at higher RPM and big power.
While we're on this subject, how do you "guide" your rods?
1. One builder whom I respect spends many hours making individual aluminum spacers to insure each rod journal has three equal spaces.
2. One builder who claims no comebacks just stretches spirolocs and puts one on each side between the rod and the piston pin boss.
3. A third builder of smaller engines doesn't use any spacers or "guides" whatsoever. His claim, on a small cylinder bore and a 2" rod journal, there's not enough tilt to worry about.
The “slack” is made up in the piston construction although #1 is doable.
NHRA SS/G
1970 AMC AMX - 390 4-speed
Interesting video on YouTube. horsepower monster. Where they build up a ford Nasar engine for off-road truck racing. it gives a really good look at the piston pin, and the Mahle pistons setup for centering the rods. they too used more big end side clearance. not a technical expose' per se but does give some insight into how its accomplished with piston design. and it is a 4.125 or larger bore. https://youtu.be/1n3riPzd0W0PackardV8 wrote: ↑Wed Jun 30, 2021 3:01 pm While we're on this subject, how do you "guide" your rods?
