How much ignition retard per pound of boost?
Re: How much ignition retard per pound of boost?
Post by F-BIRD'88 »
Don't get to wrapped up in the DCR stuff for supercharging.. Better to look at the BDS blower site fir non intercooled boost vs compression ratio on various fuels octanes. Your non intercooled blow thru will be similar..
You want to sneak up on the tune anyway..
Boost and timing...
cam it to go fast.
plovett
Post by plovett »
F-BIRD'88 wrote: Sat Jul 10, 2021 1:03 am Don't get to wrapped up in the DCR stuff for supercharging.. Better to look at the BDS blower site fir non intercooled boost vs compression ratio on various fuels octanes. Your non intercooled blow thru will be similar..
Boost and timing...
cam it to go fast.
Here is the BDS chart. Thanks.
In-Tech
Post by In-Tech »
plovett wrote: Sat Jul 10, 2021 9:48 am Here is the BDS chart. Thanks.
Garbage chart, boost is simply a restriction of flow.
-Carl
plovett
Post by plovett »
In-Tech wrote: Sat Jul 10, 2021 12:09 pm
Here's a plain old web link.
https://www.blowerdriveservice.com/TechnicalCharts
bill jones
Post by bill jones »
---what are you using for a distributor?
---have you given any thought to the rotor index--and what happens when the electronic retard happens and the rotor is still in the same spot
---need to get a witness hole into a spare donor cap where you can shine the timing light inside there to see just where that rotor index actually is at various rpms---before---and during the boost retard conditions
---you could set up an adjustable low air pressure source to create the pressure to manually retard the spark for testing for checking at various rpms without having the blower actually hard enough to operate the boost retard
plovett
Post by plovett »
bill jones wrote: Sat Jul 10, 2021 2:53 pm ---what are you using for a distributor?
I have an MSD 8594 and a 6AL. I just got a 6BTM. No vacuum advance. Naturally aspirated I was running the black bushing for 18 degrees advance. I used 18 initial and 36 total. It was all in below 3000 rpm. I can't remember what springs I had in there. One heavy silver and one light silver?
I had not thought of how to verify the true ignition retard. Those are good ideas. Thanks!
plovett
Post by plovett »
How do you figure what octane is need for what compression ratio and boost (or flow) then?
Post by F-BIRD'88 »
I have another better chart at home.. Will post later.
af2
Post by af2 »
Exactly!!! And to go further read the plugs at the end of the run to see what is really going on. All this retard shit is crazy. When you have the correct setup to start with you are golden!
GURU is only a name.
plovett
Post by plovett »
F-BIRD'88 wrote: Sat Jul 10, 2021 5:50 pm I have another better chart at home.. Will post later.
I would like to see the chart if don't mind posting it. Thanks.
paul
Post by F-BIRD'88 »
Boost Fuel CR When on GOOD pump gas the idea is to keep the effective CR below 12.5:1
Orr89rocz
Post by Orr89rocz »
I still dont have much faith in compression charts and boost. A lot of combinations i have seen wouldnt work according to those
Post by F-BIRD'88 »
Can you post the details of a combo that did not work?
Starting with what specific fuel was in the tank
af2
Post by af2 »
Orr89rocz wrote: Sun Jul 11, 2021 1:20 pm I still dont have much faith in compression charts and boost. A lot of combinations i have seen wouldnt work according to those
Same here all the methanol blown running 35lbs+ between 13:1 and 14.5:1 CR are at between 25 and 28 degrees at 9500 rpm. All Hemi's with a 6-71. They run in the high to low 6's.
plovett
Post by plovett »
F-BIRD'88 wrote: Sun Jul 11, 2021 12:43 pm Boost Fuel CR When on GOOD pump gas the idea is to keep the effective CR below 12.5:1
Thanks!
