Don't recall exactly but it was about $600Can for the HEI style all in.skinny z wrote: ↑Sun Sep 05, 2021 11:23 amHmm..Firechicken wrote: ↑Sun Sep 05, 2021 11:01 am
Bought online through their website with PayPal and shipped to Canada with no issues.
Just might be the ticket. It's gets pretty old messing with weights, springs, adjustable vacuum cans and limiter plates.
Curious, what was your total cost shipped to your door in CDN funds?
Progression Ignition Distributor
- New Member
Re: Progression Ignition Distributor
Yes, I saw that. Just wondering if you have been using it?Firechicken wrote: ↑Sun Sep 05, 2021 10:58 amDistributor has a built in map sensor that you connect to manifold vacuum and then vacuum advance is programed with the app. No moving parts...treyrags wrote: ↑Sat Sep 04, 2021 8:06 amDo you use vacuum advance on it?Firechicken wrote: ↑Fri Sep 03, 2021 10:55 pm Over 2 months with mine now and still working perfectly. What a beautifully simple way to tune timing. Street strip car just driven on weekends mostly so not a ton of run time.
Really hope it holds up over time and totally recommend this otherwise.
- New Member
Yes, using all the features including boost retard. That's the beauty of it, easily making full use of timing in all areas.treyrags wrote: ↑Mon Sep 06, 2021 3:29 pmYes, I saw that. Just wondering if you have been using it?Firechicken wrote: ↑Sun Sep 05, 2021 10:58 amDistributor has a built in map sensor that you connect to manifold vacuum and then vacuum advance is programed with the app. No moving parts...
