Q16 or M5?
408 Nova
Q16 or M5?
Post by 408 Nova »
Or something else?
For a small tire heads up class 2700 lb 68 Nova, 15:1 plus compression, sb2.2 shifting at 8500, 'Glide, and 4.10's.
Also, is it okay to have a gasoline/alcohol fuel system in the front of the car, as far as safety goes?
Re: Q16 or M5?
We had 2 of them.. One methanol (engine). other race gas (nitrous system)
408 Nova
Re: Q16 or M5?
Post by 408 Nova »
Fuel systems up front?
Also, which fuel is best for na?
Re: Q16 or M5?
Yes both up front under hood.
Engine was run on both methanol and on 114 octane race gas N/A, at various times. Went quicker and faster on Methanol.
408 Nova
Re: Q16 or M5?
Post by 408 Nova »
Thanks for the information!
David Redszus
Re: Q16 or M5?
Post by David Redszus »
408 Nova wrote: Mon Aug 02, 2021 10:42 am Fuel systems up front?
Q16.
steve cowan
Re: Q16 or M5?
Post by steve cowan »
408 Nova wrote: Sun Aug 01, 2021 6:17 pm Or something else?
Australian super stock gas classes run pro stock truck engines 358 ci SB2.2 splayed and Wedge head deals
15.2,15.3 compression 9000 rpm etc
Up until the unleaded thing came in a couple of years ago they run ROO 16 , C25 with good success
We are talking around 900- 930 hp at the time.
Not sure what carb or carbs you are running but I would talk to Mark Whitener of Lightning racing carbs on this forum.
I think Q16 is a powerful fuel that requires more than a jet and air bleed change.
Would be interested in Mark's opinion.
408 Nova
Re: Q16 or M5?
Post by 408 Nova »
David Redszus wrote: Mon Aug 02, 2021 4:50 pm
Q16.
Care to elaborate sir?
KnightEngines
Re: Q16 or M5?
Post by KnightEngines »
I've had real good results lately with C85, on a 600hp engine it was up 15hp on E85, which is pretty damn close to what I'd expect on methanol.
Outside the box a little, but worth a look - & it's relatively cheap.
Mike Laws
Re: Q16 or M5?
Post by Mike Laws »
C45
Mike Laws Performance
smeg
Re: Q16 or M5?
Post by smeg »
So shifting at 8500 so peak power around 8000? I would use methanol. I have done a lot of track and dyno testing on this and if you are making peak at 8500 and shifting 9000+ I would use a racing gasoline.
408 Nova
Re: Q16 or M5?
Post by 408 Nova »
smeg wrote: Wed Aug 04, 2021 8:04 pm So shifting at 8500 so peak power around 8000? I would use methanol. I have done a lot of track and dyno testing on this and if you are making peak at 8500 and shifting 9000+ I would use a racing gasoline.
Yessir, peak at 8000, shift at 8500.
I'm still gathering parts, but I'm really close to finishing this thing and dynoing it.
And thanks for the info.
smeg
Re: Q16 or M5?
Post by smeg »
M5 will pick up more than straight methanol as well.
408 Nova
Re: Q16 or M5?
Post by 408 Nova »
smeg wrote: Thu Aug 05, 2021 12:42 am M5 will pick up more than straight methanol as well.
I don't know for sure, but I've heard the "5" is for 5% nitromethane.
Re: Q16 or M5?
Per Prof. Google: "Q. Does M5 contain Nitromethane? A. M5 contains nitroparaffins, which are relatives of nitromethane in the same chemical family.Aug. 17, 2009"
