Curious what others think: https://www.researchgate.net/profile/Mo ... dacted.pdf
He spent some time looking at droplet size and quoting Meyer and Heywood (1999):
- *Typical (older) PFI injector produces droplets between 70 and 150 micrometer
*Larger droplets (ability to atomize throughout their travel through the intake tract and cylinder) depend upon "fuel film transient behavior (surface tension?)
*Intake airflow velocity doesn't really influence the mean droplet past the intake valve below 1,000 RPM (but a strategy of only injecting into an open valve DID result in smaller mean diameters going into the cylinder)
- *multihole injectors produce a finer droplet distribution with narrower angles, which helps a lot at low velocities (obvious...)
*Single hole injectors have a higher momentum which means better targeting and better ability for fuel droplets to fight reversion and make it into the cylinder
A GREAT look into closed valve vs. open valve injection- which was largely what I was looking to learn and how I found the paper.
- * Closed-valve: spray angle and trajectory more important than droplet size 60-70 micrometer droplets bouncing off the intake valve are typical at WoT
*Open-valve: starting @ 2,000-3,000 RPM air flow starts altering the fuel droplet trajectory, but does not significantly impact droplet size yet. Testing say a droplet size of 100 micrometers when open-valve injection started near the valve open; BUT when open valve injection occured late in the compression stroke, fuel droplet size was reduced to 50-80 micrometer (a big accurate injector timed backwards from the intake valve close (Large, accurate Injector Dynamics style injectors timed backwards from valve close) saw an increase in atomization.)
* SMD values under 25 past the valve can significantly decrease wall wetting with OVI strategies (Holthaus in 1997 theorized that you'd need droplets smaller than 10 micron; this seems to be an upward revision of that number)
*A high velocity exhaust system is even more important if adopting an OVI strategy (Wish I understood this part...)
Later in the paper it was mentioned that open valve port injection reduces exhaust gas temperatures by 30-40 degrees C vs. firing upon a closed valve; isn't this just evidence that more cooling is happening in the cylinder and that such a strategy could potentially allow for more knock resistance at a given DCR / cylinder pressure?
It was also mentioned that open valve port injection improved the ability to burn lean mixtures.
A Stone 1999 quote stated that 10% of fuel could be saved if cycle to cycle variations could be eliminated and mentioned that fuel concentration at the spark gap early in the ignition event has a strong coorelation to later max pressure development.
The study's experiment then quoted Zhai and Lai 1995 and Berkmuller 1997 that stated that open valve injection gives you an average of 4.3% richer fuel stratification around the spark plug.
--> My takeaway is that a large spark plug gap combined with a late Open-valve injection can significantly extend the lean-burn limit, which was clearly called out as a key take-away in the study's 2nd Abstract paragraph. (Lean limit extended from 14:1-17.5:1 @ 1,000 rpm and low pressures, and from 17.5:1 to 12:1 at 1,500 RPM and 1.5 bar. (This was using an intense "duel split injection" strategy that isn't possible on a dual valve engine.)
-With direct injected engines ALL the cooling potential of the fuel is going directly into the cylinder and we see higher compression ratios as a result. Feels like a late, open valve port fuel injection strategy is moving port injection closer in that direction. (Especially if combined with an injector that's starting out with a smaller fuel droplet to begin with as it's got so much less TIME / DISTANCE in the intake tract to evaporate.)
I thought that it highlighted some interest potential advantages of a late, open-valve via large, accurate port fuel injectors injection strategy that I hadn't seen testing data or academic references for previously, anyway.
Some of this makes me really wish for a large capacity, 12 hole port fuel injector with their 50um initial droplet size, but large, or even moderate capacity and 12 hole injectors don't seem to really be a combination that exists...
I like the idea that a late open valve port injection strategy has the potential to buy you a little bit of extra breathing room with a high DCR engine on the edge of pump gas AND when combined with a powerful ignition system and a decent spark plug gap, to push lean cruise mixtures even a bit leaner.
We've all seen the port injection vs. carb or throttle body injection results a bunch of times now, but it would be interesting to see port injection maximized for the best possible atomization and cooling in this way vs. carb / throttle body injection, IMHO; maybe someday...
I've also seen a few high velocity header dyno tests that clearly highlighted that fuel was being sent out the exhaust at overlap and a large and late open valve injection strategy seems like it would help with that if the fuel isn't being introduced until after the exhaust valve has already closed.
I know that some folks have tried switching to timing their port injection backwards from ivc (Belgian1979) and reported no real gains, but I'm interested in hearing from others who have tried this.
