How many passes on NOS?
econo racer
Post by econo racer »
I have a 1 gallon dedicated cell for the 175 nitrous kit. About how many passes before needing to add fuel? using 105 race gas.
dannobee
Re: How many passes on NOS?
Post by dannobee »
Ignoring safety factors. 0.5 BSFC *175hp = 87.5lbs/hr or 13.5gal/hr or 0.224gal/minute.
*About* 4 minutes total run time if you could use every ounce of fuel. You'd still need safety factors though. Plan accordingly.
Alaskaracer
Post by Alaskaracer »
Just like with the bottles, you should fill your tank after every pass and change bottles after every pass. Consistency will suffer if you run a bottle more than once and your fuel load changes.....unless you're just making passes for fun, every little thing helps. But I'd never make two runs on a tank a fuel even if I knew I had plenty to do so....always fill every pass.....
Mark Goulette
Authorized Amsoil Retailer
1980RS
Post by 1980RS »
My one friend who ran a 2 gal would fill it after 3 passes but he was hitting the engine with a 250 shot. I would say fill it make a pass and then look to see how much you used then you will kinda know when to fill it.
econo racer
If I spray the plate over a 5 gal. pale for 10 seconds it seems like only very little fuel is use. I am guessing 7-9 passes easy. out of a 1 gal cell.
lefty o
Post by lefty o »
id fill every couple of passes. if it runs dry, or picks up air, things are gonna get expensive quickly. :shock:
Dave Koehler
Post by Dave Koehler »
Fuel jet used?
Fuel pressure used?
How many seconds of run time?
jsachs1
Post by jsachs1 »
Don't forget temperature vs bottle pressure.
John
Dave Koehler
He's only concerned about the fuel side of things at the moment.
