I've got a 2009 NC Miata I endurance race in ChampCar and want to run in WRL. It needs every whp it can get, so to that end I decided to try and max out the header. We started with RoadsterSport's 1.8 (1-7/8" primaries ~17" in length) MAX Power header (pics here). I assumed this was kept short to mate up with the factory exhaust system, meaning there would be gains to be had with longer runners. It was also built with the popular 2.5L swap in mind, so I reasoned the primaries might be too large in diameter.
I called Burns Stainless, who designed the header for the NP01 prototypes which use NC MZRs (though the newer NP01-Evo variant have aftermarket cams). They said they've done a lot of testing with this motor, and recommended 28" primaries (measured from collector to head flange) with 1-5/8" diameter, in 16 gauge stainless.
I also consulted PipeMax (my PMW file is here), which said 1-5/8" diameter and 20.5" length:
Code: Select all
--- Primary Tube Specs : Race Header • Single Tube diameter size ---
Peak TQ Diameter Range = 1.472 -to- 1.597 Best Length = 19.561 -to- 21.521 inches
Best Mid-Range Diameter = 1.597 Best Length = 19.561 -to- 21.521 inches
Peak HP Diameter Range = 1.597 -to- 1.722 Best Length = 19.561 -to- 21.521 inches
--- Primary Tube Harmonics --- ( One-End-Closed Tube = Odd Numbered Harmonics )
1st Harmonic = 67.017 to 68.976 inches long ... typically never used ( too long to fit any Vehicle )
3rd Harmonic = 19.561 to 21.521 inches long ... highly recommended , best Torque and HP Curve
5th Harmonic = 10.070 to 12.029 inches long ... shortest recommended ( Shorty or very Hi-RPM Header )
7th Harmonic = 6.002 to 7.962 inches long ... shortest recommended ( Shorty, Hugger, or Log Style )
9th Harmonic = 3.743 to 5.702 inches long ... shortest recommended ( Log Style or Cast-Manifold )
11th Harmonic = 2.305 to 4.264 inches long ... shortest recommended ( Log Style or Cast-Manifold )
--- Collector Specs : Straight Tube Collector • or Straight with a slight Merge shape ---
Peak TQ Diameter Range = 1.866 -to- 1.991 Best Length= 17.093 -or- 34.185 inches
Best Mid-Range Diameter = 1.991 Best Length= 17.093 -or- 34.185 inches
Peak HP Diameter Range = 1.991 -to- 2.116 Best Length= 17.093 -or- 8.546 inches
--- Collector's Harmonics --- ( Both-Ends-Open Tube = Odd and Even Numbered Harmonics )
1st Harmonic = 136.741 inches long ... longest recommended with Mufflers and TailPipes
2nd Harmonic = 68.370 inches long ... longest recommended with Mufflers and TailPipes
3rd Harmonic = 34.185 inches long ... greater Low RPM Torque -to- Peak Torque RPM
4th Harmonic = 17.093 inches long ... highly recommended , best Torque and HP Curve combination
5th Harmonic = 8.546 inches long ... reduced Peak Torque , higher RPM HP gains possible
6th Harmonic = 4.273 inches long ... reduced Low RPM Torque , even though Tuned Length
Trusting Burn's experience, I bought a PPE 1-5/8" 16 gauge header. It has ~30" long primaries designed for lots of mid-range in autocross applications. It sucked. This is a same-day dyno of it vs. the 1.8 MAX. Both had a 20" pipe after the collector:
I wasn't expecting it to make the top-end of the MAX, but I'd thought it would beat it somewhere. I then hacked the collector off and slid on a Burn's collector. Both these pulls had no pipe after the collector:
It's hard to say for sure with a chassis dyno, but the Burns might've made a bit more up top. The collectors look the same on the inside, but Burns' has a much more pronounced neck:
I then shortened the PPE's runners by 2.75". They now measure ~27" (28.5, 28.9, 26.9, and 25.1). That helped:
I then attach a 42" pipe to the collector. This made a big difference in mid-range, but didn't do much for the 5200-7400 range the car operates at:
So I reasoned maybe the problem is post-collector exhaust length? PipeMax said the third harmonic is 34", so I started cutting down the pipe:
The only material difference was in the 3-4,000 range, and it obviously liked the longer pipe more. There are differences elsewhere, but this dyno isn't super repeatable.
PipeMax recommends an 18" post-collector pipe, so I started cutting it down again from 24":
Again the only material difference is the mid-range, so I decide to stop. We then do a leak-down test to verify the health of the motor (2-5% on all cylinders).
Here's the best PPE pull vs. the best 1.8 MAX pull:
Any thoughts on what to do next? Burns' specs were obviously incorrect. I could more extensively modify the PPE header and try PipeMax's 20" spec, or I could (more easily) lengthen the 1.8 MAX header to 20". Given how far the PPE header was behind the 1.8 MAX at higher RPM, my inclination is that it wants more primary diameter than both Burns and PipeMax indicated. I'm not sure if motors are more tolerant of too much primary than too little, but it sure doesn't look like 1-3/4" would even be enough.
1-7/8" seems like a lot of primary for a motor making 40whp a hole though doesn't it?
Thanks for any help!
