Very convoluted infirmation.
Using Dyno CFM reading for carb sizing
Re: Using Dyno CFM reading for carb sizing
I always complete my tuning with out the air turbine.
It seems to have an effect on carb metering and booster signal.
Adger Smith
Adger Smith Performance Engines
903 794 7223 shop
903 824 4924 cell
adgersperf@aol.com e-mail
903 794 7223 shop
903 824 4924 cell
Hi Adger,Adger Smith wrote: ↑Sat Sep 04, 2021 12:11 am I always complete my tuning with out the air turbine.
A honeycomb element in the tract will help with that tremendously.
-Carl
-Carl
I’ve never seen a eddy carb perform as good as quickfuel.
A 383 cuin engine, running at 100%VE, will require a specific amount of air volume, depending on rpm.eric8 wrote: ↑Thu Sep 02, 2021 2:03 pm This seems like the most obvious metric for determining an engine’s true cfm needs, so it has me wondering. My mild 430 hp 383 SBC on a Superflo dyno had a cfm rating of 592 at 5,900 rpms. A 650 cfm carb should in fact be plenty, no? Just thinking out loud. Am I missing something?
5000rpm...554 cfm
6000........665
7000........776.
The air volume is dependent on whether the air contains fuel vapor or not. The air mass will depend on air density.
CID x RPM / 3456 = CFM for 100%VEeric8 wrote: ↑Thu Sep 02, 2021 2:03 pm This seems like the most obvious metric for determining an engine’s true cfm needs, so it has me wondering. My mild 430 hp 383 SBC on a Superflo dyno had a cfm rating of 592 at 5,900 rpms. A 650 cfm carb should in fact be plenty, no? Just thinking out loud. Am I missing something?
383 x 5,900 / 3456 = 654 CFM.
- Stan Weiss
Just a WAG as to what might be.
Code: Select all
_______STPPwr__STPTrq___BMEP_____Fuel___BSFC___UnCorr_UnCorr_Correct___A/F______Air
__RPM____CHP___Clb-ft____PSI___lbs/hr__lb/hph____HP___Torque__Factor__Ratio____SCFM____VE%
_5900___430.0___382.8__150.8___208.53__.4850___430.0___382.7__1.0001__13.00___591.9___90.6
Sorry for the delay. Here’s the dyno sheetStan Weiss wrote: ↑Sat Sep 04, 2021 2:39 pm Just a WAG as to what might be.
Code: Select all
_______STPPwr__STPTrq___BMEP_____Fuel___BSFC___UnCorr_UnCorr_Correct___A/F______Air __RPM____CHP___Clb-ft____PSI___lbs/hr__lb/hph____HP___Torque__Factor__Ratio____SCFM____VE% _5900___430.0___382.8__150.8___208.53__.4850___430.0___382.7__1.0001__13.00___591.9___90.6
Stan,Stan Weiss wrote: ↑Sat Sep 04, 2021 2:39 pm Just a WAG as to what might be.
Code: Select all
When calculating carb CFM, what allowance is made for fuel vapor, if present?
- Stan Weiss
David,David Redszus wrote: ↑Tue Sep 07, 2021 7:53 pmStan,Stan Weiss wrote: ↑Sat Sep 04, 2021 2:39 pm Just a WAG as to what might be.
Code: Select all
That CFM would be like what is measured by the dyno air turbine. When I do carb CFM calculations I ignore the fuel vapor.
