Another carb question
- af2
I just ordered 2 avs 500 carbs and didn't think if the metering kits will work from the carters I have. On a 355 Edelbrock XC8 Hopefully they are the same.
GURU is only a name.
Re: Another carb question
The jets and rods are the same as Carters, just the numbering system is different is what I was told.
being Edelbrock AVS carbs yes the metering rods should interchange, the original AVS carter carbs had three steps on the metering rod, and will fit in the AFB as well.
As stated same, but numbering is different.
I had a Carter Kit and bought a Edelbrock to find out...
Adger Smith
Adger Smith Performance Engines
903 794 7223 shop
903 824 4924 cell
adgersperf@aol.com e-mail
903 794 7223 shop
903 824 4924 cell
While the AFB Carter & Edel rods physically interchange, I noticed the E rods have a muuuch larger difference between the power step & cruise step, compared to Carter rods.
