E85 experimental
agertz1
E85 experimental
Post by agertz1 »
Likely 95% street use. 4.100" bore 3.228" stroke + 43" per cyl. Target is 65+ hp. per cyl. Hp max should be 7K + rpm. with good torque band.
Air cooled iron cylinders and aluminum liquid cooled head,( pair of cyls). I prefer reverse-flow coolant. What size(1) coolant port on exh. side ? Exh. is on bottom,
so air entrapment not likely. (2) exit, top) on intake side. Sizing between In/out ?
Thoughts ? Thanks, Art.
agertz1
Re: E85 experimental
Post by agertz1 »
Nobody ? #-o
dannobee
Post by dannobee »
Porsche 956's had air cooled cylinders with water cooled heads. 962's were completely water cooled, but the heads are similar. Since the heads were individual castings, a coolant manifold connected everything.
Looking at the google images can give you an idea of the size of the water inlet and outlet. HP was approx 100hp/cyl for reference. FWIW
agertz1
Post by agertz1 »
Will do. Thanks.
