Holley vents
Rattlin' Bones
Holley vents
Post by Rattlin' Bones »
Hi New here.
I have a 3310 Holley that has had the choke horn milled off including the vent tubes. What will not having them or what difference does the length make? I remember race cars used to join them with a piece of hose with a notch at the top?
Cheers
Geoff2
Re: Holley vents
Post by Geoff2 »
Fuel slosh is the problem. Accelerating & braking, fuel can slosh into the carb bores.
lefty o
Re: Holley vents
Post by lefty o »
airflow can just plain suck gas right out of the vent tubes when they are there. cant imagine how bad it could be with the tubes cut flush.
levisnteeshirt
Re: Holley vents
Post by levisnteeshirt »
I'd like to try the hose extension for the vents to go outside of the filter for a dirt tracker , or anything with a filter ,, i think it would keep the bowl at atmospheric , and should help carb function
Re: Holley vents
Doing that would result in a pressure differential between the fuel bowls and the carb bores/boosters that varied with RPM, due to the restriction of the filter design and cleanliness, thus producing unpredictable changes in AFR.
econo racer
Re: Holley vents
Post by econo racer »
I have used 90 degree plug wire boots. :D
