Real basic 500hp SBC street engine
KnightEngines
Post by KnightEngines »
Dyno'd this yesterday, was a bit of a surprise package, goal was a very drivable 450+hp on a tight budget.
I figured it'd make 470-480hp @ 6200rpm - a safe margin above requirements.
It's real simple:
4 bolt 010 block
Scat 383 kit with pro I beams & icon pistons.
Romac Street balancer.
Mellings pump, moroso pan.
DRP heads with a pro-port cnc program through them (aussie company, in Ballarat), 2.08/1.6 ferrea 5000 valves.
Flow 300/220 cfm, around 210cc.
Crane 96870 springs etc.
Budget stainless 1.6 rockers.
Team G intake (all I could get, choices are limited right now, I wanted a 300-25 strip dominator)
Quickfuel cq750 carb on a 1" tapered spacer.
Cam is an off the shelf crane 242/250 on 106 solid flat tappet.
11:1 compression.
Fired it up, bedded the cam & rings, put the inner valves springs in & had it dialled in in 5 pulls, used like 3 gal of fuel total.
Jetting ended up at 74 front, 83 rear with a 3.5 power valve.
33 deg timing.
506hp @ 6300rpm, 479lb @ 4700rpm.
smeg
Re: Real basic 500hp SBC street engine
Post by smeg »
Great combo this, just to let you know Pro Port are in Bendigo, victoria.
Fatman
Post by Fatman »
Whats the port area through the push rod pinch on those heads?
KnightEngines
smeg wrote: Fri Oct 08, 2021 9:00 pm Great combo this, just to let you know Pro Port are in Bendigo, victoria.
Shit, you're right, Pro port CNC, Bendigo!!!
Rod does great work.
KnightEngines
Fatman wrote: Fri Oct 08, 2021 9:08 pm Whats the port area through the push rod pinch on those heads?
From memory, 2.1" mcsa.
tuffxf
Post by tuffxf »
Awesome result Tony!
Old mate should be stoked!
HQM383
Post by HQM383 »
What’s it going in?
1/4 mile potential?
econo racer
Post by econo racer »
Nice match up :D Man the torque=stump puller :D
KnightEngines
HQM383 wrote: Sat Oct 09, 2021 2:33 am What’s it going in?
1/4 mile potential?
HQ coupe, older guy has owned it since '83.
Manual trans, 3.55 diff - not a 1/4 mile car.
In a car set up for strip it'd be in the high 10's I'd think.
rustbucket79
Post by rustbucket79 »
All I see is proof of the importance of quality cylinder heads. Nice job! =D>
