Line2Line Coatings Any Experience Updates?
fabr
Post by fabr »
https://www.line2linecoatings.com/ Of those here that have used it,are you still using it? Any updates on pros/cons?
1972ho
Re: Line2Line Coatings Any Experience Updates?
Post by 1972ho »
I’ve had a set done it works but that first load of oil will end up with the break in material in it,and trying to break it in at home while trying load the engine per there break in procedure was kind of hassle and after I pulled the pistons later on the skirt size was where it needed to be.
fabr
Post by fabr »
Good to hear the size was on target.I'm curious if it is used still. Past reviews were mostly positive . Am wondering how much/if it is used on higher HP endurance engines today.
dunnitagain
Post by dunnitagain »
Ive used them on everthing from a 50Hp 4str outboard to 600Cuin offshore engines. Never had a problem.
TKM in Denton NC uses the coatings from street builds to Pro Mod .
levisnteeshirt
Post by levisnteeshirt »
First oil drain will make you scratch your head , 2nd was fine
