SBF Roush Crankshaft
I have a retired Roush engine in the shop. This thing has some odd parts! The main thing I am running into is locating main bearings. This thing has a 2.00 inch main journal on crank and a thrust width of 1.038. The thrust bearing is all separate pieces. Looks like a clevite bearing number is MB-3852h. The guy that owns the engine is trying to contact someone at Roush. If any one can help with locating bearings I would certainly appreciate it.
Re: SBF Roush Crankshaft
Is the crank a billet?
You might want to consider getting your old bearings coated and reuse them if possible. The last time I had to buy those was a couple of years ago and was told I was getting some of the last ones available.
Carlquist Competition Engines
I really didn’t think of that. Problem is it was disassembled somewhere else and don’t have them all. I will keep this in mind. Thanks
None in stock1972ho wrote: ↑Fri Oct 15, 2021 10:55 pm https://www.jegs.com/i/Clevite-MAHLE/69 ... H/10002/-1 What about these
