Cam Spec.’s for GM’s new 1000 HP pump gas engine
Has anyone learned what the Camshaft Specs are on Chevys new 632 C. I. Pump gas Engine which has an advertised 12 to 1 static C. R. ? Mark H .
Re: Cam Spec.’s for GM’s new 1000 HP pump gas engine
Better question what is the cost? 12-1, probably direct injection. What kind of engine management system ? How high is the fuel pressure going to be? What will be the price of the engine management system?
The ZZ572 is $16K. The ZZ632 will easily be more. 1004/727 x $16,300 = $22,500 just to get the bidding war started.
As for other details, sounds like one needs to attend SEMA.
270/282 @ 0.050", 0.780"/0.782" lift billet hydraulic roller cam
86lb/hr injectors, "Kit includes pre-programmed, self-learning control system." Whatever that means.
https://www.gmperformancemotor.com/parts/19432060.html
$100 per horsepower sounds about right.
Cheaper than NASCAR. Waaaay cheaper than Formula One.
4.75” stroke and 7000RPM is some pretty serious piston speed.
at 100K, that thing had best perform sexual favors for you while driving.
I wonder what the LSA is? Do you think it has a warranty? If it does it probably has a chip that records highest RPM and how long it was at that RPM.
No way thats 100k lol just a fill in number because they likely dont have the price out yet
I like it, 5/16 stem 2.45 titanium valves and hyd roller, nice stuff
I do not think it comes with any chip or ECM from what i read.
Are the parts in this engine existing available stock or new parts made only for this engine?
There is no way GM will price this Engine at 100K, they won’t if they want to sell any. Mark H.
