Machine valve spring locators
Can you cut a locator in a lathe to reduce it from .060 to .030? Need 8 .060 and 8 .030. Or are they so hard you will destroy the tools used?
I also need to open the hole from .570-.630 to fit the guide. I have the locators so thats why I ask, if I can modify what I have.
Re: Machine valve spring locators
Yep, done it plenty of times.
Hardening is usually only .010" deep or so & not really that hard.
Machine the bottom, use a carbide tip & lower rpm than you'd use for a tough steel.
Sometimes you'll have to knock the hard edge down where it sticks up above the freshly machined surface, belt sander works great.
What's the most you machined them down?KnightEngines wrote: ↑Mon Oct 25, 2021 8:05 am Yep, done it plenty of times.
I've machined locators down to .030 - .035 thickness many times.
Are they I.D. or O.D. locators?
If I.D. locators what is the O.D. of the inner lip?
If your machining the I.D. to .630 you must have some meat left to locate the spring.
If they are I.D. locators and are thin in this area I'd leave them at .570 and machine the guide boss down to .565 if possible.
If O.D. locators its no problem to cut I.D. to .630
Id locators. .790resurrectionjoe wrote: ↑Tue Oct 26, 2021 1:10 pm I've machined locators down to .030 - .035 thickness many times.
They are Comp 4776-16, 4777-16 has same od diameter and .630 id so thought that was safe?
I should of been more clear what's the thinnest
Around .030" is the thinnest I've gone.BOOT wrote: ↑Tue Oct 26, 2021 10:35 amWhat's the most you machined them down?KnightEngines wrote: ↑Mon Oct 25, 2021 8:05 am Yep, done it plenty of times.
Use a CBN insert. You can also trim hardened splines and shafts with these.
Cheers.
Cheers.
