Dart NEW REVISED SHP SBC Cylinder Heads
BOOT
Re: Dart NEW REVISED SHP SBC Cylinder Heads
Post by BOOT »
MELWAY wrote: Mon Nov 15, 2021 5:45 am This new casting. Look a lot like AFR castings.
I wonder if they come out of same factory as the
AFR enforcer heads?
Anyone confirm if these New Dart castings are USA made?
AFR enforcer are offshore castings and machined by AFR, that casting is kinda copy of Dart pro1 plat. The offshore copy goes under many names or can be found generic on ebay. I have a few sets of them and they are not the same as either Dart 180 SHP
I don't know for certain if the NEW Dart SHP is USA cast, herd rumors that they may be not but don't think it was china in that rumor. I know Dart has had foundry issues.
BOOT
Post by BOOT »
1980RS wrote: Mon Nov 15, 2021 9:24 am Ask any Stock or Super Stock guy about out of the box heads and see if they run'em that way, I bet not. My friend who runs an A/Stock Camaro had his new GM BBC heads that cannot be messed with other than valve work re-done, they picked up a bunch redoing the seats and valves and those were new heads. I always go back to Vortecpro's video on new head and valve seat runout. I touch up every seat and valve on my own stuff I get and for me the results have paid off performance wise.
Not trying to be rude but your not telling me anything that I've not read/herd at 1000 times. Every part has to be checked even assembled heads need to be taken apart, inspected and cleaned.
If my stuff was Max effort then I'd buy the equipment or pay someone to do a good VJ, it's not. I'm into diy and I improve what I can with what I have.
1980RS
Post by 1980RS »
BOOT wrote: Mon Nov 15, 2021 11:39 am
A great valve job on any head is not a max effort, by the way when I just talked with my friend he said that valve job over the our of the box was worth 42hp. Money well spent for a good amount that amount of hp.
BOOT
Post by BOOT »
Apples to Oranges
1980RS
Post by 1980RS »
BOOT wrote: Mon Nov 15, 2021 12:19 pm Apples to Oranges
:roll:
BOOT
Post by BOOT »
OK as promised here are some details
Flow is up, spec sheet only had @500 numbers.
11cfm on the intake
32cfm for the exhaust
Head now has a boss for a center coolant port & bosses that look to be for Stahl header pattern. Over all quality has improved alot and I like the new casting. They moved the spark plug over a bit. Deck appears to be thicker and flange gaskets fit is better.
Ron Miller
Post by Ron Miller »
1980RS wrote: Mon Nov 15, 2021 12:12 pm
So, what is the Hot set up on the valve job with the Edelbrock 401 head and the 934 head?
Ron Miller
Post by F-BIRD'88 »
Any chance of flow testing these new SHP heads, Boot?
BOOT
Post by BOOT »
F-BIRD'88 wrote: Mon Nov 15, 2021 6:03 pm Any chance of flow testing these new SHP heads, Boot?
Actually I contacted a few other youtubers that flow heads and was gonna send the NEW SHP head(also offered the poor quality OLD) for them to make their own video flow testing. But no takers, so both heads are shipping out. I decided to go ahead and return the OLD head and just got off the phone to exchange the NEW head, so who knows when I'll get that replacement. Not really interested myself but figured many would like to see the actual flow numbers tested by an independent and it would be good content for someone else, figured wrong I guess.
WeingartnerRacing
Post by WeingartnerRacing »
BOOT wrote: Mon Nov 15, 2021 6:52 pm
I said I would do it. I never said I wouldn’t.
Eric Weingartner
Weingartner Racing LLC
918-520-3480
www.wengines.com
WeingartnerRacing
Ps this is what the last dart shp 180 looked like I flowed. It doesn’t look like you old dart head.
Eric Weingartner
918-520-3480
www.wengines.com
steve cowan
Post by steve cowan »
As cast 180 SHP I bought about 12 months ago.
steve cowan
As cast exhaust NO PIPE and tested with short pipe
Adger Smith
Post by Adger Smith »
GARY C wrote: Sat Nov 13, 2021 5:54 pm
af2 wrote: Sat Nov 13, 2021 4:57 pm Am I looking at a pro-action/ Rhs head?
Pro Action/RHS head
Look at the spark plug location on the Dart vs RHS/PA
check out the Olds /Chevy heads that were used on Harry Gant's Skoal Bandit
Casting # 22542525
Adger Smith
Adger Smith Performance Engines
903 794 7223 shop
903 824 4924 cell
adgersperf@aol.com e-mail
BOOT
Post by BOOT »
WeingartnerRacing wrote: Tue Nov 16, 2021 12:48 am I said I would do it. I never said I wouldn’t.
You said maybe December and in my last message I asked you to confirm. Then since you didn't reply, I figured that you were no longer interested. But it doesn't matter now, the heads are no longer my problem.
