Carburetor spacers
1980RS
Re: Carburetor spacers
Post by 1980RS »
Last year my peanut port 461 BBC engine with the Single plane intake liked the 2" 4 hole tapered spacer the best. The RPM Performer like the 1" open spacer the best and hated the 4 hole spacer.
BOOT
Post by BOOT »
If Speedmaster has a sale like the past few years, then their spacers will be pretty cheap for Black Friday. Obviously not as nice as my HVH but one can easily spend hundreds on spacers to try out, I have LOL
I got a 1" and 2" tapered that seem to be flat and good enough for my use.
rustbucket79
Post by rustbucket79 »
If the speedmaster spacers are like their heads and intakes, the holes in the spacers will be all over the place. [-X
Verify after installation, I have come across spacers that I tossed in the trash due to misalignment.
ArizonaGuy
Post by ArizonaGuy »
When one spacer needs significantly more idle mixture (no other changes), what does that tell me?
HQM383
Post by HQM383 »
ArizonaGuy wrote: Fri Dec 03, 2021 9:46 am When one spacer needs significantly more idle mixture (no other changes), what does that tell me?
Reduced atomization and distribution.
1980RS
Post by 1980RS »
So, which way is the right way to use a tapered spacer on an intake? 4 holes down or up? Asking for a friend :lol:
steve cowan
Post by steve cowan »
I like the Reher and Morrison tapered spacer and shear plate.have used on a few combinations
racear2865
Post by racear2865 »
1980RS wrote: Fri Dec 03, 2021 6:14 pm So, which way is the right way to use a tapered spacer on an intake? 4 holes down or up? Asking for a friend :lol:
Try it both ways. I bet u will be surprised with the results
reed
1980RS
Post by 1980RS »
racear2865 wrote: Fri Dec 03, 2021 8:56 pm
reed
Thanks, we got in an argument about that.
steve cowan
Very interesting,
I want to try a reverse taper 2" spacer as well but didn't want to mention it as I have not heard or talked to anyone about it 🤔
My post around eight back answers that for at least one SBC. I'd like to hear details re any engine that made more power with the four holes down.
1980RS
Post by 1980RS »
MadBill wrote: Sat Dec 04, 2021 4:52 pm
I ran it with the 4 holes up on my car and it picked up almost 2 tenths and 1 mph then the next week put the same spacer on the dual plane intake and promptly lost 2 more tenths after the baseline that day, buy the open 1" spacer was .003 better than the single plane and the 2" tapered spacer on the single plane intake. Kind of a wash if you ask me.
