late model hemi 5.7 cylinder head question
bentvalves
Post by bentvalves »
can I take .020" off the deck without using a thicker headgasket?
if not, could anybody recommend a gasket manufacturer that does?
edit: I am seeing that cometic do.
Re: late model hemi 5.7 cylinder head question
Post by mag2555 »
It sounds like your looking to mill the head for the sake of cleaning it up , and not for a compression increase, right?
Is this just one head off the motor that needs to ge milled?
bentvalves
yes mill to clean the pair.
heads passed pressure test.
miniv8
Post by miniv8 »
I wouldn't think this increased preload on the lifters would hurt anything
Post by mag2555 »
Yes, I would agree!
Even so called limited travel Hydro lifters made for hi rpm / racing have a .050" plunger travel range !
BillK
Post by BillK »
If you are just doing a clean up cut why would you need to cut .020" off ??? Those heads generally clean up with less than a .005" cut and to be honest with you if they are warped more than that they should be replaced.
