can I take .020" off the deck without using a thicker headgasket?
if not, could anybody recommend a gasket manufacturer that does?
edit: I am seeing that cometic do.
late model hemi 5.7 cylinder head question
Re: late model hemi 5.7 cylinder head question
It sounds like your looking to mill the head for the sake of cleaning it up , and not for a compression increase, right?
Is this just one head off the motor that needs to ge milled?
yes mill to clean the pair.
heads passed pressure test.
I wouldn't think this increased preload on the lifters would hurt anything
Yes, I would agree!
Even so called limited travel Hydro lifters made for hi rpm / racing have a .050" plunger travel range !
If you are just doing a clean up cut why would you need to cut .020" off ??? Those heads generally clean up with less than a .005" cut and to be honest with you if they are warped more than that they should be replaced.
