2.56 Gear, Stock Converter, 4100 Pounds, NA 11s?
vortecpro
Re: 2.56 Gear, Stock Converter, 4100 Pounds, NA 11s?
Post by vortecpro »
Very nice!
Dragginwagon406
Post by Dragginwagon406 »
rgalajda wrote: Fri May 20, 2022 11:45 am !975 Monte Carlo S
454 .030 over, Icon 779 pistons, 1/16 Total Seal rings, 9.5:1 compression, .043" quench
346236 peanut port heads, 2.190 intake valve , 1.880 exhaust , pocket porting, runners and chambers cleaned up, 3 angle valve job with blending,
Custom flat tappet camshaft on Voodoo lobes, 273 : 227@.050" / 107 LSA -- .571 lift with 1.79 roller tip rocker
Carburetor: Holley 780 cfm 3310-1 , Date coded 1975 , restored myself with some modifications
Exhaust: 1 7/8 headers into 2.5 inch exhaust with balance pipe
Rear axle: original 2.73:1 , positraction installed
Beautiful, how did it run?
1.87, 11.72 @ 120, 4110 lbs, 2.56 gears, stock stall, 225/70-15 Cooper Cobras
My sleeper video - https://youtu.be/tcOh6gQ_K_E
rgalajda
Post by rgalajda »
I have never had it to the drag strip , I just do touring, but it seems strong. Very happy with the build.
Bought it about 4 years ago from original family owners, 47,000 miles. Was a 350 , pulled motor and replaced with 454 and 400 turbo, that I built.
Now has 57,000 miles.
Bought it locally in southern Ontario Canada. Floor boards have original paint, no rust. Car had never been winter driven and always parked in garage, they told me. The seller was 80 years old and her husband had passed a few years prior. She decided it was time to let it go.
The daughter and son in law still drove it once in a while. It was still plated and insured.
All original chrome and interior, and original brake lines. Added 17" wheels and tires.
skinny z
Post by skinny z »
rgalajda wrote: Sat May 21, 2022 9:51 am
Bought it locally in southern Ontario Canada.... no rust.
Generally those two aren't included in the same sentence. (I'm a born and bred Ontario boy and have seen my share of rust!)
Kevin
1980RS
Post by 1980RS »
Put some cam in that big engine and watch the track numbers wake right up, you need something on a 108 LCA for more torque to gain a better 1/8 mile for a better overall ET.
Dragginwagon406
1980RS wrote: Sun May 22, 2022 2:16 pm Put some cam in that big engine and watch the track numbers wake right up, you need something on a 108 LCA for more torque to gain a better 1/8 mile for a better overall ET.
The challenge is, I really like the smooth idle and driveability. I'm going to work on the car.
The next race will have 275/60-15 ET Street radials, The 1' taller tire will lower the rpm at least 200 at the end of the track compared to the 225/70-15 Cooper Cobras, and consequently, add mph. As well, going to change the fuel pickup, feed and vent lines to 1/2". This aside from the requisite oil change between races.
1980RS
Post by 1980RS »
Dragginwagon406 wrote: Mon May 23, 2022 11:05 pm
Just keeping the same cam specs put putting the cam on a tighter LCA would make a lot more low to mid-range torque that would better your ET. Getting a better MPH is just like getting a cookie, but if your into roll racing it's a great thing.
Dragginwagon406
Wouldn’t a tighter LSA would have more overlap, idle rougher, and run out of breathe quicker?
One of the coolest race videos I have of my car…you’ll see what I mean if you watch it.
https://www.facebook.com/groups/7655170 ... 619538808/
Time slip from race above.
1980RS
Post by 1980RS »
Dragginwagon406 wrote: Wed May 25, 2022 10:10 pm Wouldn’t a tighter LSA would have more overlap, idle rougher, and run out of breathe quicker?
Not always, I had a cam that was ground on a 106° LCA for a BBC with a pretty short duration and it idles like a stocker. It was done by 5500 rpm. Last year I ran an old 400 in my car with a Comp cam that was on a 108° LCA and it ran pretty quick and had a slightly rougher idle than stock. It's where the opening and closing events of the cam that make the lope sound. Remember what you are doing with that big car, it needs torque to get it moving, HP keeps it moving. My 461 Peanut Port engine last spring ran 11.16@118mph with a 105° LCA cam and 8:1 compression with the wrong converter but boy does it get going in a hurry and pulls to 6500 if needed.
bob460
Post by bob460 »
This is a Beast, the only thing i would change is to run a M/T radial 235x60x15 on a 10 inch wide wheel...... =D>
vortecpro
Post by vortecpro »
Grandma's Monte looking a little "sketchy"
