Hello,
would it be difficult to start an engine with a LC160 intake camshaft?
Engine has VVT and intake camshaft is fully retarded at start up
Thanks
LC160 camshaft at start
Re: LC160 camshaft at start
In general regardless of the engine in question I would say yes.
Retarded ignition timing and too low of a cylinder pressure than what’s needed to let the starter spin the motor over will leave you hung out to dry!
If starting fluid will not make the motor at least kick when cranking then you for sure have problems!
What cylinder pressure are you seeing when cranking ?
Hi mag,mag2555 wrote: ↑Wed Nov 24, 2021 8:20 am In general regardless of the engine in question I would say yes.
engine is still in pieces, and I'm just thinking about all the options I have for it.
Thanks
