Billet Barra motor!
Circlotron
Billet Barra motor!
Post by Circlotron »
Somebody had to do it. Read it and weep.
https://www.facebook.com/bulletraceengi ... 5999999118
Momus
Re: Billet Barra motor!
Post by Momus »
What are the cylinder liner details?
KnightEngines
Post by KnightEngines »
They're LA sleeve ductile liners I think.
CRS
Post by CRS »
Crest CNC made a billet barra block last year.
https://www.facebook.com/11332770679161 ... 284577287/
Actually looks like a barra block too.
Schurkey
Post by Schurkey »
I had to research what the hell a "Barra" engine was.
A development of a development of a development of a development of a Ford Falcon Six-popper. God bless the Aussies, for polishing a turd and actually making it shine.
https://en.wikipedia.org/wiki/Ford_Barra_engine
bob460
Post by bob460 »
Same company is making a billet SBF cleveland block in 2022......about $11k.... =P~
Momus
Post by Momus »
Schurkey wrote: Fri Dec 17, 2021 10:32 pm I had to research what the hell a "Barra" engine was.
The original 4 main bearing Aussie Falcon engine came out of a 1950's Canadian tractor.
I think they preserved the bore pitch all the way through.
BLSTIC
Post by BLSTIC »
It's the same bore spacing and similar bolt patterns as Holden and some Chrysler 6's too. Meaning our kickass heads can conceivably fit other engines...
Windage tray definitely does
panic
Post by panic »
Barra & Ford Oz (144, 170, 200, 250, etc.) 4.080"
Holden Red (202, etc.) 4.045"
Slant 6 (170, 198, 225) alternately 3.98" & 4.00"
Chrysler Oz "hemi" (265 etc.) 4.40"
BLSTIC
Post by BLSTIC »
Interesting. There was a twin cam head casting that was reputedly good for Ford Holden and Chrysler with different machining, and people definitely used the Ford crank in the Holden.
I wonder if they didn't just put the middle in the middle and let the tolerance stack up? It's not like 3mm in valve position negates going from 9 low non crossflow ports to what's basically a hemi with some quench (if I'm remembering the Ford crossflow combustion chamber right)
JC565Ford
Post by JC565Ford »
They've done a pretty darn good job at it ( One of my top 3 favorite dyno vids)
https://www.youtube.com/watch?v=c2eWHNSaSZU
Momus
Post by Momus »
BLSTIC wrote: Wed Dec 29, 2021 12:49 pm Interesting. There was a twin cam head casting that was reputedly good for Ford Holden and Chrysler with different machining, and people definitely used the Ford crank in the Holden.
Ford headed Holdens are out there as well.
