Push Rod Length: Shorter vs Longer
Walter R. Malik
Re: Push Rod Length: Shorter vs Longer
Post by Walter R. Malik »
skinny z wrote: Sat Nov 27, 2021 8:32 pm When your calculated push rod length falls between two standard measurements, do you go longer or shorter?
Say I find 7.385" is ideal. So is it 7.375 or 7.40" ?
This is a hydraulic roller with .575" lift via 1.6 rockers.
Whichever would allow the better geometry on the pushrod side.
skinny z
Post by skinny z »
Walter R. Malik wrote: Mon Nov 29, 2021 8:32 pm
I'll look into this should this same scenario come up with my own project.
This was for a poster on another forum and I think that deal is sealed. But eventually, I'll be working on my own pile of parts. Again.
Kevin
steve cowan
Post by steve cowan »
I was recently reading where Larry tested on dyno and track
More hp with Sweep pattern on pushrod side but potentially more guide wear.
Obviously application specific,
skinny z
Post by skinny z »
steve cowan wrote: Tue Nov 30, 2021 3:21 pm
Guide wear is precisely the issue.
Kevin
steve cowan
Personally I get pushrod length with heavy spring I am using, I find big difference in checking spring and heavy roller spring
skinny z
Post by skinny z »
steve cowan wrote: Tue Nov 30, 2021 3:29 pm Personally I get pushrod length with heavy spring I am using, I find big difference in checking spring and heavy roller spring
Same here.
Even 140 lbs on the seat makes a difference.
Kevin
