Dyno tuned 434 SBC 11:1 AFR 245 Solid Roller
swampbuggy
Re: Dyno tuned 434 SBC 11:1 AFR 245 Solid Roller
Post by swampbuggy »
Scott, do you have a friend with a 1050 Dom. ??
ChopperScott
Post by ChopperScott »
I like the idea of a dominator. I'm sure I could probably find one to borrow. That would also require an adapter plate, new throttle cable and bracket, and air cleaner assembly. Will it fit under the hood?
I'm currently working on adding an isolator for the cowl hood using the 4150 carb with a new drop base...
'73 Camaro Z/28 NETO/N
434 SBC 11:1, 1.294, 6.178 @ 108.87, 9.81 @ 134.93 (3060#, Naturally Aspirated, Sunoco Ultra 94)
Chopper Air Port 917-589-1278
bob460
Post by bob460 »
If your looking at buying a new carb, maybe give the twin blade 1100cfm 4150 bt TMC.
You don't need an adapter and will fit under your hood.
swampbuggy
Hello Bob, good thought....yeah i forgot about the Twin Blade and the home base is right close to me ( 50 ) mins. away . My only thoughts or questions about the design of the mentioned Carb is the draw ( for lack of a better word ) on the boosters and quality of atomization . Has anybody learned any information about this. Without a doubt Dyno and track testing proves any New design to be good or not. Mark H.
ChopperScott
The Viking Crusaders have arrived...
6.50camaro
Post by 6.50camaro »
ChopperScott wrote: Wed Jul 27, 2022 1:37 pm The Viking Crusaders have arrived...
What spring rate did you get? Dan
ChopperScott
6.50camaro wrote: Wed Jul 27, 2022 1:45 pm What spring rate did you get? Dan
Springs are 14", 110#
Shocks: C315AM-D
Compressed Height 14.75"
Extended Height 23.75"
Stroke 9.00"
Ride Height Range: 18-3/8" to 20-1/4"
ChopperScott
ChopperScott
Testing out the GoPro...
https://youtu.be/i5RIPc8Nkxk
DA was over 2700. Corrected E.T. is 9.934 @ 135.267...
skinny z
Post by skinny z »
.004 light! Nice.
Kevin
1980RS
Post by 1980RS »
skinny z wrote: Mon Aug 08, 2022 5:57 pm .004 light! Nice.
Yes sir, Chopper Scott choppin down the tree.
steve cowan
Post by steve cowan »
Yep,
Sounds great and runs the number easily :D
ChopperScott
Thank you, gentlemen. Just to clarify, that last video is a TnT run after I got knocked out of competition. I ran heads-up against a 3rd Gen Camaro with a high compression 434 sbc on Q-16 with a 150 shot of nitrous.
1980RS
Post by 1980RS »
ChopperScott wrote: Mon Aug 08, 2022 10:27 pm Thank you, gentlemen. Just to clarify, that last video is a TnT run after I got knocked out of competition. I ran heads-up against a 3rd Gen Camaro with a high compression 434 sbc on Q-16 with a 150 shot of nitrous.
150 shot? well that just cheating :lol:
prairiehotrodder
Post by prairiehotrodder »
How much difference was there on the dyno with the different carbs ? You said the 850 did the best ?
Thankyou
Brian
