Dyno tuned 434 SBC 11:1 AFR 245 Solid Roller
cwodgers
Re: Dyno tuned 434 SBC 11:1 AFR 245 Solid Roller
Post by cwodgers »
Dragginwagon406 wrote: Tue Dec 07, 2021 4:42 am Nice running engine.
Looks to have a windage issue - you’re down 10 psi as the rpm climbs. I’m not familiar enough to say if it’s correctable on the long stroke small block, but it can’t be good.
What’s the bottom end and pan consist of? Any oil restrictors? Are the drains on these heads wide open?
Edit: a kick out style pan might help.
Do you plan on running a vacuum pump?
From what I have seen that is a pretty narrow range and could depend on the number of pulls and the oil. If it is break-in oil and pull 7 that would be a supprisingly good result.
ChopperScott
Post by ChopperScott »
prairiehotrodder wrote: Thu Aug 18, 2022 2:30 pm How much difference was there on the dyno with the different carbs ? You said the 850 did the best ?
Thankyou
Brian
Here's a pull with the 950...
'73 Camaro Z/28 NETO/N
434 SBC 11:1, 1.294, 6.178 @ 108.87, 9.81 @ 134.93 (3060#, Naturally Aspirated, Sunoco Ultra 94)
Chopper Air Port 917-589-1278
ptuomov
Post by ptuomov »
Awesome thread and results.
ChopperScott
Ran the car on Sunday at Atco Yesteryear Drags. It was losing traction after the hit, knocking the car out of the groove. 60' and ET were way off the mark. I need to get a camera on the suspension. The only change since running at Island was a carb swap with the XP850. Corrected mph is 133.343 on this run...
https://youtu.be/l6XQ3xkIDs4
ChopperScott
Rat Pack 1 was two cars in front of me in the same lane. It obviously wasn't a track issue...
skinny z
Post by skinny z »
ChopperScott wrote: Mon Aug 22, 2022 10:02 pm Rat Pack 1 was two cars in front of me in the same lane. It obviously wasn't a track issue...
I hope he has a cupholder!
Kevin
BrazilianZ28Camaro
Post by BrazilianZ28Camaro »
To the OP,
Keep an eye on the drop base filters systems, once I chassis dynoed a mild 358 SBC with a drop-base 3" tall x 14" OD paper element air filter and it was 23 WHP LOSS compared to no filter. Eye opener.
BTW, have you noticed any ET or MPH change with the hood on?
'71 Z28 street strip car
Pump gas All motor SBC 427
3308 lbs-29x10.5 Hoosiers
NEW BEST ET
ChopperScott
BrazilianZ28Camaro wrote: Tue Aug 23, 2022 12:03 am To the OP,
No argument here. My only other option is cutting a hole in the hood.
So far the quickest/fastest pass has been with the hood on.
skinny z
Post by skinny z »
BrazilianZ28Camaro wrote: Tue Aug 23, 2022 12:03 am Keep an eye on the drop base filters systems, once I chassis dynoed a mild 358 SBC with a drop-base 3" tall x 14" OD paper element air filter and it was 23 WHP LOSS compared to no filter.
I understand that there can be issues with the filter case lid getting to close to the choke horn and that this can cause problems.
Apparently, the shape of the base and lid has an effect as well.
Kevin
David Vizard
Post by David Vizard »
Your torque works out at 1.412 lbs/ft per cube which is good for an 11/1 CR.
What length collectors are you running on your headeers. I would think you need something in the 12 inch range.
DV
David Vizard
DV
BrazilianZ28Camaro
ChopperScott wrote: Wed Aug 24, 2022 11:58 am
Getting cold air from the outside would be nice, probably worth some ET.
I'd spect a big change in MPH with the hood on. Aero drag is a big factor at the big end.
Good luck, keep us posted!
NEW BEST ET
ChopperScott
David Vizard wrote: Fri Aug 26, 2022 12:25 am Your torque works out at 1.412 lbs/ft per cube which is good for an 11/1 CR.
What length collectors are you running on your headers. I would think you need something in the 12 inch range.
DV
Hello there. Welcome back.
The headers have 1.875" x 29" primaries, 3.5" x 10" collectors, and 3.5" x 12" slip-on collector extensions w/turndowns.
Tom68
Post by Tom68 »
skinny z wrote: Wed Aug 24, 2022 12:05 pm
Yer 3" is a low filter for a drop base, 4" may have fixed it.
BrazilianZ28Camaro
Tom68 wrote: Fri Aug 26, 2022 8:24 pm
Probably would help, but wouldn't fit under the hood, unfortunatelly.
NEW BEST ET
