Dyno tuned 434 SBC 11:1 AFR 245 Solid Roller
ChopperScott
Re: Dyno tuned 434 SBC 11:1 AFR 245 Solid Roller
Post by ChopperScott »
54chevkiwi wrote: Tue Dec 07, 2021 7:25 am Did you happen to get any video of it on the dyno..?
Sure...
https://youtu.be/jdyBt7thiKs
Dragginwagon406
Post by Dragginwagon406 »
ChopperScott wrote: Tue Dec 07, 2021 1:45 pm
Sure...
Sounds awesome.
In regards to the pan, that appears to be the diamond scraper like the 20408 pan I use. I can tell you, Mark trimmed it out for the GM windage tray which is mounted off the studs. I’ve read people theorize that the high speed oil sees the diamond as solid, and the oil still splashes. Need a window to look through to see what may be happening.
1.87, 11.72 @ 120, 4110 lbs, 2.56 gears, stock stall, 225/70-15 Cooper Cobras
My sleeper video - https://youtu.be/tcOh6gQ_K_E
ChopperScott
Dragginwagon406 wrote: Tue Dec 07, 2021 7:10 pm
Sounds awesome.
Thanks.
I also have a Moroso 21017 that has better oil control, but it would not fit with my stock front chassis. I could have dyno tested with the better pan, but I wanted results with the pan to be used in the car.
'73 Camaro Z/28 NETO/N
Chopper Air Port 917-589-1278
1980RS
Post by 1980RS »
Sure...
That 434 sounds sweet, Great numbers and great build.
ChopperScott
Patiently waiting...
ChopperScott
Dragginwagon406 wrote: Tue Dec 07, 2021 4:42 am Do you plan on running a vacuum pump?
No vacuum pump. Here’s the 1 7/8 primary headers with 3 1/2 collectors, and crankcase evac hoses, that will be bolted on in the car. I would have liked to dyno test the engine with these, but they were still in the car on another engine at that time.
ChopperScott
I’m currently waiting on a custom built, bolt together, torque converter from ProTorque. While I’m waiting, I’ll swap out the MW 28/35, 5.29 third member with a Strange 35/35, 4.57. Trying to get ready for a track rental test and tune, and competition on the same weekend next month.
mt-engines
Post by mt-engines »
ChopperScott wrote: Wed Apr 20, 2022 4:46 pm I’m currently waiting on a custom built, bolt together, torque converter from ProTorque. While I’m waiting, I’ll swap out the MW 28/35, 5.29 third member with a Strange 35/35, 4.57. Trying to get ready for a track rental test and tune, and competition on the same weekend next month.
Why are you doing a bolt together?
ChopperScott
mt-engines wrote: Wed Apr 20, 2022 7:58 pm Why are you doing a bolt together?
Simple answer... ease of maintenance and tunability, while minimizing shipping and service costs.
bob460
Post by bob460 »
ChopperScott wrote: Thu Apr 21, 2022 10:14 am
What's the cost of the bolt together converter?
Monza355
Post by Monza355 »
What kind of converter did protorque spec out for your combo if I may ask ?
ChopperScott
bob460 wrote: Thu Apr 21, 2022 8:03 pm What's the cost of the bolt together converter?
It's an additional $400 option.
ChopperScott
Monza355 wrote: Fri Apr 22, 2022 4:32 am What kind of converter did protorque spec out for your combo if I may ask ?
Bullet Race Series, 8" bolt together w/ billet aluminum drive cover, 30 spline, mechanical diode, billet stator, with approximate 5200-5500 stall range.
ChopperScott
54chevkiwi
Post by 54chevkiwi »
Hey i just saw the link on the youtube vid to the yellow bullet thread.. what lemgth primaries in them dyno headers..?
Sorry if its mentioned in this thread, i went straight from there to here to ask
