Dyno tuned 434 SBC 11:1 AFR 245 Solid Roller
ChopperScott
Re: Dyno tuned 434 SBC 11:1 AFR 245 Solid Roller
Post by ChopperScott »
ClassicComp wrote: Tue Sep 13, 2022 8:57 am Scott where is your location?
I’ve a friend with a chassis shop that could help I’m sure.
Hello there. I'm located in West Milford, NJ.
'73 Camaro Z/28 NETO/N
Chopper Air Port 917-589-1278
ChopperScott
ChopperScott
Ready for the Dover Nostalgia drags at Lebanon Valley this weekend...
1980RS
Post by 1980RS »
ChopperScott wrote: Tue Sep 20, 2022 6:20 pm Ready for the Dover Nostalgia drags at Lebanon Valley this weekend...
I can't race my Camaro at the Nostalgia drags, seems the powers that be only let '66 and earlier race with the hiked up front end cars. Looks good Scott :mrgreen:
I found this video you need to watch of some guy testing his 355 engine out.
https://youtu.be/ttDBwt7lcSM
ChopperScott
1980RS wrote: Wed Sep 21, 2022 12:40 am I found this video you need to watch of some guy testing his 355 engine out.
I found a pic of that guy swapping that 355 in the street!
skinny z
Post by skinny z »
ChopperScott wrote: Wed Sep 21, 2022 1:35 am
Coming soon to a neighbourhood near me!
Kevin
ChopperScott
Made a few passes at Lebanon Valley this past weekend. I captured a couple of videos of the rear suspension with the GoPro mounted out back. Any feedback would be appreciated.
1.43 60'
R:8 C:8
https://youtu.be/sltn91rsUU8
1.38 60'
R:8 C:10
https://youtu.be/Cw7gD6yz5jk
vortecpro
Post by vortecpro »
ChopperScott wrote: Mon Sep 26, 2022 7:02 pm Made a few passes at Lebanon Valley this past weekend. I captured a couple of videos of the rear suspension with the GoPro mounted out back. Any feedback would be appreciated.
1.43 60'
R:8 C:8
1.38 60'
R:8 C:10
It seems your out quite a ways before the engine comes on. Who's converter?
ChopperScott
vortecpro wrote: Mon Sep 26, 2022 7:28 pm It seems your out quite a ways before the engine comes on. Who's converter?
ChopperScott wrote: Fri Apr 22, 2022 5:10 pm Pro Torque, Bullet Race Series, 8" bolt together w/ billet aluminum drive cover, 30 spline, mechanical diode, billet stator, with approximate 5200-5500 stall range.
Launch control was set at 4500 rpm off the transbrake.
1980RS
Post by 1980RS »
:lol:
1980RS
Post by 1980RS »
1.43 60'
R:8 C:8
1.38 60'
R:8 C:10
I see both runs spun for a few feet, but look good.
cwodgers
Post by cwodgers »
ChopperScott wrote: Mon Sep 26, 2022 7:38 pm
I have a hard time comprehending your dyno number given the et. I have a 400sbc in a 64 corvette. Dynoed at 602.5 HP @6400rpm. It was dynoed with no accesseories. I run a mechanical waterpump and alternator in the car. Total weight with me in it 3,250 lbs and I ran 10.55 with DA 5500' which also corrects to about 9.9 at sea level. I foot brake with 255/60R15 street tires. I was a little rich on the dyno so I leaned it out and staggered the jetting to lean out the two rich corners so I might be 615hp if Im lucky with the accessories. How much does your car weigh and are there any launch issues?
ChopperScott
cwodgers wrote: Tue Sep 27, 2022 8:18 pm I have a hard time comprehending your dyno number given the et. I have a 400sbc in a 64 corvette. Dynoed at 602.5 HP @6400rpm. It was dynoed with no accesseories. I run a mechanical waterpump and alternator in the car. Total weight with me in it 3,250 lbs and I ran 10.55 with DA 5500' which also corrects to about 9.9 at sea level. I foot brake with 255/60R15 street tires. I was a little rich on the dyno so I leaned it out and staggered the jetting to lean out the two rich corners so I might be 615hp if Im lucky with the accessories. How much does your car weigh and are there any launch issues?
The engine was dynoed without accessories. On the car there is a mechanical water pump, alternator, and power steering pump. I weighed it on the scale at the end of the track on Friday after the first pass. It was 3060# with me in it. Launch issues? Have a look for yourself...
1.43 60'
R:8 C:8
1.38 60'
R:8 C:10
cwodgers
Post by cwodgers »
Nice video. I have seen a number of them on youtube. Pretty good videos. The ones you take of the whole car is that from a phone. I would like to take some of mine but my friends cell phone doesnt capture it well when it is down the track. What does your car weigh? Any idea about the density altitude there?
cwodgers
Post by cwodgers »
ChopperScott wrote: Wed Sep 28, 2022 1:07 pm
1.43 60'
R:8 C:8
1.38 60'
R:8 C:10
Your car leaves pretty hard. Suspension looks like it is working well. I still have the independant rear suspension, a composite leaf spring. I turned down a dana 60 gear, bored out the housing and used stout axles and half shafts. I get 1.51 60' foot- breaking but it accelerates hard after that but doesnt look anything heroic. I switched to a glide from a turbo 350. I made a lot of changes to the engine but I picked up a lot. With the old hydraulic roller my best was 10.86 at DA of about 3300'.With a comp XE292r, I had a run last time out that would have been 10.49 at DA 5300' if I hadnt breaked because I passed the guy. We should have some better air (4000' DA) this weekend. Im hoping for 10.30s. You might try a powerglide with a 1.8 or 2.0 1st. I use a BTE with a 2.0 1st.
