Tesla Model S Plaid full performance tests 1/4 Mile
i wanted to see how well my ET_Analyst software models an Electric Car ???
.... it seems it did pretty close !
differences between SAE J1349 -vs- SAE J607 HPCF is about 1.04 to 1.06 range
the YouTube and Internet Article said 1020 HP SAE J1349
which could be around 1060.8 HP -to- 1081.2 HP ??
the very 1st Run ET_Analyst Data looks like what i'd expect
to see with an Electric Car with CVT transmission !
However , the rest of the Runs , such as , 4th and 6th Runs
look like the Telsa had battery problems ?????
....... anyone care to comment on this ???????
https://insideevs.com/news/519291/tesla ... nce-tests/
2.01 to 60 MPH * PLAID DRAG STRIP TESTING *
https://youtu.be/azBffkgb26c
http://www.dragtimes.com/Tesla-Model-S- ... 31887.html
Track:
Orlando Speed World Dragway, FL, USA
1st Run :
July 9 2021 11:00am
1.480
3.970
6.013
120.22
7.776
9.264
151.83
4th Run :
July 9 2021 12:39 pm
1.489
3.979
6.017
118.48
7.770
9.248
150.65
6th Run :
July 9 2021 1:00 pm
1.506
4.015
6.054
119.74
7.814
9.302
149.45
Jul 09, 2021 at 2:51pm ET
By: Mark Kane
DragTimes recently was able to spen some time with the all-new,
red Tesla Model S Plaid at the Orlando Speedway drag strip
and record full performance tests.
When put in Drag Strip Mode, the car quickly reported that it is ready for the job
so the team was able to conduct multiple runs.
The times were very good,
including 1/4 mile in 9.248 seconds at 150.65 mph in the second run.
That's just 0.001 s behind Jay Leno's record.
We listed the results from the video below,
but please take note that some include rollout (like the best 0-60 mph time in 2.01 seconds).
The Dragy appears to report a true 0-60 mph time around 2.21 seconds.
1st try - results (dragy):
0-60 mph (96.5 km/h) - 2.21 seconds
1/8 mile - 6.03 seconds at 120.82 mph
60-130 mph - 4.71 seconds
100-150 mph (240 km/h) - 4.74 seconds
1/4 mile - 9.28 seconds at 151.48 mph
Track measure: 1/4 mile - 9.264 seconds at 151.83 mph
2nd try - results (dragy):
1/8 mile - 6.01 seconds at 121.23 mph
60-130 mph - 4.64 seconds
100-150 mph (240 km/h) - 4.67 seconds
1/4 mile - 9.25 seconds at 151.99 mph
Track measure: 1/4 mile - 9.248 seconds at 150.65 mph
https://insideevs.com/features/544554/t ... k-driving/
https://insideevs.com/news/521791/tesla ... -vs-raven/
https://electrek.co/2021/11/26/tesla-mo ... rter-mile/
1.436
3.831
5.816
125.10
7.541
8.994
155.10
Track:
1st Run :
July 9 2021 11:00am
1.480
3.970
6.013
120.22
7.776
9.264
151.83
4th Run :
1.489
3.979
6.017
118.48
7.770
9.248
150.65
6th Run :
July 9 2021 1:00 pm
1.506
4.015
6.054
119.74
7.814
9.302
149.45
By: Mark Kane
1.436
3.831
5.816
125.10
7.541
8.994
155.10
Re: Tesla Model S Plaid full performance tests 1/4 Mile
added 2 Choices : Air Density Altitude in Feet and HP Correction Factor
Seems like it would be interesting to see what effect air density has on MPH and if the lower density shows up as higher developed horsepower at the end of a high altitude track.
Certainly it won't much difference to ET, but it could easily be a 10 "horsepower" difference.
EVs are fastest/quickest with a fully charged battery pack. Performance slows as it is drained.
Also, Tesla has balanced ultimate cost,weight and performance, using wiring harness which will handle 1/4-mile at a time, but not full speed closed course racing. On longer road courses, the Tesla will reduce power in less than one full lap to avoid overheating the wiring harness.
Which is entirely understandable. Most other vehicles in the segment would do the same on a road course, and the plaid is more about who's eco-wang can smack down the loudest gas guzzlers on the street*.PackardV8 wrote: ↑Fri Dec 03, 2021 12:42 pm Also, Tesla has balanced ultimate cost,weight and performance, using wiring harness which will handle 1/4-mile at a time, but not full speed closed course racing. On longer road courses, the Tesla will reduce power in less than one full lap to avoid overheating the wiring harness.
Also that wheel? On a road course? Ewww...**
*A noble pursuit if there ever was one. I did the similar in my pale purple wrx hunting daihatsu charade back in the day
**still, if given half a chance to drive that car, gimme gimme gimme
thanks for that Info !PackardV8 wrote: ↑Fri Dec 03, 2021 12:42 pm EVs are fastest/quickest with a fully charged battery pack. Performance slows as it is drained.
the 1st Run had full Battery charge ... and my Simulation shows it
from that point on... it appears there were Battery problems or Telsa software protecting wiring harness or combo of both ??
Also you can see they were making almost back-to-back Runs according to ET Slip's time of Day
just looking only at the Time Slip Data
its easy to see which Run is quicker or slower ,
however , its hard to tell from the ET Slip just how much HP varied so much between Runs,
and it was easy for my Software to show the large differences in HP output at different distances
that normally you would not think was happening from the ET Slips .
- Dave Koehler
I can't speak to lithium batteries.
I do know from hard learned experience that lead acid batteries that are tasked hard repeatedly never recover the to same capacity as it had during the previous task or the one before it. It's a slow road to battery failure.
If lithium is the same way it's another little detail the ev fans don't want to discuss.
They're not, Dave.Dave Koehler wrote: ↑Fri Dec 03, 2021 9:23 pm I can't speak to lithium batteries.
Lithium batteries have a lot of variability in chemistry options.
The chemistry is tuned to fit the aims of the application.
Whether it is durability, fast charging, cost etc, each priority calls for a different chemistry (there is a lot of R&D work being done on battery chemistry, huge demand for experts in the field).
From what I see, there is still a lot of upside potential in battery development.
Agree with all the above.SchmidtMotorWorks wrote: ↑Sat Dec 04, 2021 12:28 pm Lithium batteries have a lot of variability in chemistry options.
The LG Chem/Chevrolet Bolt LiOn batteries were built with the best technology available in 2016 and they've still had twelve fires in 180,000 batteries and they're a slow charging design.
My prediction is as battery development attempts to leapfrog into ultra-rapid charging, thinking that's what the market demands, this has the potential to be not just fires but explosions.
That ultra rapid charging is getting faster and faster.
Vehicles like EVTOLs where very gram counts prefer not to carry the hardware needed for fast swaps.
I'm working on this one:
https://archer.com/
https://archer.com/
Doesn't Speedtalk have an electric car sub section?
Boot ,
i never noticed that Forum
CamKing please move this Topic to the "Electric & Hybrid Vehicle ** NEW **"
