Help with sbc 440 cu in dirt track motor. What cylinder heads
Streetstock35
Post by Streetstock35 »
2 barrel motor, run c&s 890cfm carb and gauge legal 500cfm, open motor rules
lefty o
Re: Help with sbc 440 cu in dirt track motor. What cylinder heads
Post by lefty o »
a 440 inch small block can use pretty much any large head on the market, 235/245 afr or similar. even a 227, as when you have to run the 500cfm carb, thats going to be your restriction.
CamKing
Post by CamKing »
Why are you running a 440ci in a class restricted to a 4412 carb ?
Is there an RPM limit ?
With that 4412 carb, and 440 cid, the highest you can make peak HP is 5,300 rpm.
With a restrictive carb a big engine usually doesn't make if any more power than a smaller one, but generally has more torque.
Streetstock35
It started its life out as a 430 with 14° RHS iron heads, we have to run a iron head, had a valve seat come outa one of them and beat up couple pistons and stuck 2 rings, so now its a 440 and want to go back to a 23° head
Streetstock35
The track i run most of the time, I can run the 890cfm 2brl carb
Streetstock35
I was just looking for a iron head recommendation on what head you guys thought would work best on what I have
CamKing
Post by CamKing »
Streetstock35 wrote: Sun Dec 05, 2021 12:51 pm I was just looking for a iron head recommendation on what head you guys thought would work best on what I have
Th head that will work best with an 890cfm carb, is not the head that will work best for a 500cfm carb.
There's about an 1,800 rpm difference between where those carbs will peak.
With the big carb, you can go with the biggest 23 degree head you can find, but that will be way too big, with the 4412 carb.
