Lifter design
Mat-it
Lifter design
Post by Mat-it »
Looking for comments on the difference between these 2 lifters. Top one in photo is new Elgin roller replacement with inner metering disc and smaller oil hole, bottom is stock 351w roller lifter with no inner disc and larger hole. Wondering if the new one is going to provide same amount of oil flow.
swampbuggy
Re: Lifter design
Post by swampbuggy »
Does Elgins paperwork not address this subject ? Mark H.
Geoff2
Re: Lifter design
Post by Geoff2 »
Different lifter companies use different methods of oil metering [ to the prods ]. Much ado about nothing.
BOOT
Re: Lifter design
Post by BOOT »
How big is the hole in your pushrod?
Mat-it
Re: Lifter design
Post by Mat-it »
Pushrod hole 0.10, old lifter hole 0.10, new lifter hole 0.060. Just seemed odd to me but this is my first build, want to do it right.
fastvette
Re: Lifter design
Post by fastvette »
The lifters meter the oil internally. A .060 hole is not a restriction.
http://www.youtube.com/watch?v=itIITBanJDs
http://www.harshmanauto.com
