Notching divider on RPM?
77cruiser
Post by 77cruiser »
I have a RPM spread bore that I want to put on my 421. It has a Vic Jr. on it now. Wondering if I should notch the divider, how much & where?
Jim
Re: Notching divider on RPM?
Post by F-BIRD'88 »
Leave the full divider in place and try out various spacer types for effect.
Post by F-BIRD'88 »
Especially if yiu drive it more than race it.
BOOT
Post by BOOT »
I'd think a smaller single plane would be nice on 421 but lots of details I don't know. Ordered a Holley 300-261 to try sometime myself for kinda street/strip SBC, might do quick video when/if it ever gets here.
Not a SBC but spreadbore RPM with a notch https://www.summitracing.com/parts/edl-7164 Looks like it's a bit biased to the rear.
BOOT
Post by BOOT »
I always liked some of the other brands basically RPM style dual plane notches, smoother than the rough cut eddy.
BOOT
Post by BOOT »
Also what cfm is the carb?
77cruiser
Post by 77cruiser »
F-BIRD'88 wrote: Tue Dec 07, 2021 7:11 pm Leave the full divider in place and try out various spacer types for effect.
Could try that.
Jim
Post by F-BIRD'88 »
Consider adding a plenum divider to the Vic Jr.
Can make it attached to a spacer for strength.
Try that and compare.
54chevkiwi
Post by 54chevkiwi »
That 406 i had that eric done the top end on had an rpm intake, he cut down the divider like the one in that pic, and put a supersucker spacer on it with an opposing cut in it like the one in the manifold.. it ended up as a sqaure hole in the middle. He wouldnt have done that if it didnt do something.. that intake was ported as much as it could be without cutting it open..
The supersucker was one with the 4 seperate holes.. i think maybe 1.5”-2” i dont remember..
Was a square bore though..
BOOT
Post by BOOT »
54chevkiwi wrote: Wed Dec 08, 2021 10:11 am That 406 i had that eric done the top end on had an rpm intake, he cut down the divider like the one in that pic, and put a supersucker spacer on it with an opposing cut in it like the one in the manifold.. it ended up as a sqaure hole in the middle. He wouldnt have done that if it didnt do something.. that intake was ported as much as it could be without cutting it open..
The supersucker was one with the 4 seperate holes.. i think maybe 1”? Maybe 1.5” i dont remember..
HVH ST4150-4AL got one of those myself 8)
edit: Whoops put wrong part number forgot there was two, second is ST4150-2AL
77cruiser
Post by 77cruiser »
BOOT wrote: Tue Dec 07, 2021 7:35 pm Also what cfm is the carb?
Large primary Qjet. So 800?
Jim
1980RS
Post by 1980RS »
You mean like this?
steve cowan
Post by steve cowan »
On a 430-440 hp 383 sbc
Track testing I found super sucker spacer worked the best on airgap
People have to think about why the divider is milled down and think why Eric milled base of spacer as well.
steve cowan
77cruiser wrote: Tue Dec 07, 2021 6:41 pm I have a RPM spread bore that I want to put on my 421. It has a Vic Jr. on it now. Wondering if I should notch the divider, how much & where?
Jim,
Has vic jnr had porting/plenum work ??
If not and you do change to airgap it would be nice to rework the jnr when you change back later on.
The airgap will be nice at low speed but run out of puff on your cubes rather quickly in my opinion
1980RS
Post by 1980RS »
steve cowan wrote: Wed Dec 08, 2021 3:09 pm On a 430-440 hp 383 sbc
That spacer sure did not work on my BBC Air Gap last time I used it. The engine liked the 1" open spacer better.
