1936/7 Jaguar 1.5 litre
Hi everybody, I am chasing main tunnel, rod tunnel and crankshaft dimensions for a 1936/7 1.5 litre 6cyl jaguar engine. If anybody has any specs it would be greatly aappreciated. Tia.
Re: 1936/7 Jaguar 1.5 litre
Sorry, can't be any help with the actual specs, but it might be worth broadening your search to include 'Swallow Sidecars' or 'SS' 1.5
Jaguar wasn't known as such until just after WW2, when they changed their name for obvious reasons
The most famous pre-war model being the 'SS100' six, which only retrospectively became known as the 'Jaguar SS100' later in history
Good luck, John
Edit :
Most of the early Jag/SS stuff was based on Standard Motor Company chassis & drivetrain, so failing all else digging up info on the SMC 1.5 of the period might help point you in the direction you need
Good luck, John
Edit :
