ICON 9929 Piston Specs
Re: ICON 9929 Piston Specs
I think I owe to this build to measure everything.
Not that's it's something special. More for my own curiousity.
Having a quick look over the chamber's and I'll bet, that because of the relief cut that was made years ago, there's some variance between cylinders.
Kevin
That question has morphed into a quest to find these below.
Or a 1/16, 3/16ths Speed Pro which looks to be an updated version of the slugs I have now.rustbucket79 wrote: ↑Tue Jan 18, 2022 12:26 am Wiseco Pro Tru Street PTS503A4 looks like a 1.560” CH. perhaps your local machine shop is a dealer and can get you a good price on a set.They come with rings.
At this point I think it'll come down to what's available.
The Speed Pro is a heavy piston but it matches what the crank was balanced for.
The Wiseco is lighter so that'll add a rebalance.
Kevin
Wait on the Wiseco’s, that’s criminal what FM charges for those pistons considering you still have to buy rings.
Yeah. That's something I've considered.
The Wisecos bring a rebalance with them though.
I'll be at the shop (I hope) tomorrow and will figure out what the plan is.
Personally, I'd like the Wisecos both for the forging and the lighter weight.
Kevin
I have stuff on order for months from USA ,pushrods, valves,TFS cylinder heads, like I said earlier I had shelf pistons on order for 6 months.
Whatever you choose to do you need to pull the trigger now as this is not going to get better anytime soon
There is a new player in the piston industry DSS Racing. They do custom pistons and very cost effective and quick.
You may want to call them and send them a custom piston sheet with your needs for a cost.
I have used them several times and quality and accuracy is spot on and turn around was about 2-3 weeks to my door for the sets I have ordered from them.
This is where I hope my engine guy has reliable sources. Much of the decision making will be made at our meeting tomorrow. The block is on it's way. (Holy Hannah it's about time isn't it?)steve cowan wrote: ↑Fri Jan 28, 2022 3:26 pm I have stuff on order for months from USA ,pushrods, valves,TFS cylinder heads, like I said earlier I had shelf pistons on order for 6 months.
Kevin
Hey Dave.ProPower engines wrote: ↑Fri Jan 28, 2022 3:45 pm There is a new player in the piston industry DSS Racing. They do custom pistons and very cost effective and quick.
Thanks for chiming in.
DSS comes up on my searches and has a presence at Summit. How is your connection to them?
My spec would be a 40 over, 5.7 rod, 3.48 stroke, 1.560" compression height, flat top (5 cc), thin ring pack, 4032 forging.
Not cheap though and it's plus rings. No weight indicated.
And there's that "special ordered" thing again.
Kevin
We had them build a set of flat tops for a 307 Chev build to replace junky silvolite 4vr cast pistons. Decent stuff. We’ve also used their LS pistons and IIRC a set of Buick 350 pistons.ProPower engines wrote: ↑Fri Jan 28, 2022 3:45 pm There is a new player in the piston industry DSS Racing. They do custom pistons and very cost effective and quick.
Further to that Steve, is the reason why the somewhat maligned Speed Pro on still on the list.steve cowan wrote: ↑Fri Jan 28, 2022 3:26 pm I have stuff on order for months from USA ,pushrods, valves,TFS cylinder heads, like I said earlier I had shelf pistons on order for 6 months.
On the pro side, they match up weight wide. Plus thinner rings than what they replace. Con? Heavy.
But still, what I've put these heavy hypereutectic pistons through, as did their previous life in another hard driven streeter, I've zero failures to report. Which is surprising really.
Quickest way back into the game, and least expensive as it turns out, is the Speed Pro.
Kevin
Just thought I would ad that Total Seal has a narrow ring set available to be used in the wider grooves as well.skinny z wrote: ↑Fri Jan 28, 2022 11:28 pmFurther to that Steve, is the reason why the somewhat maligned Speed Pro on still on the list.steve cowan wrote: ↑Fri Jan 28, 2022 3:26 pm I have stuff on order for months from USA ,pushrods, valves,TFS cylinder heads, like I said earlier I had shelf pistons on order for 6 months.
But still, what I've put these heavy hyper-eutectic pistons through, as did their previous life in another hard driven streeter, I've zero failures to report. Which is surprising really.
They are a gapless top ring and having used them they are a nice upgrade when looking at a piston that has a wider ring groove. Not to mention you can get the wider radial section for faster ring excitement and sealing.
Seems most basic ring manufactures offer the top ring in steel but the radial depth is about .080"-.100" narrower then the 2nd ring which can create issues with ring flutter and loss of seal.
You would need to confirm the groove depths before ordering just to save a issue with the pistons diamentions differing from the ring set..
I realize you are on a super tight budget and these rings are more then a basic stock replacement ring set.
Now there's an interesting option. I'll discuss that with the shop later today. Apparently, they have a lead of a tic for tac replacement piston but, and this is where this started, has a 5/64th's ring. I'll throw that Total Seal idea out there and see what comes of it.ProPower engines wrote: ↑Sat Jan 29, 2022 11:31 amJust thought I would ad that Total Seal has a narrow ring set available to be used in the wider grooves as well.skinny z wrote: ↑Fri Jan 28, 2022 11:28 pmFurther to that Steve, is the reason why the somewhat maligned Speed Pro on still on the list.steve cowan wrote: ↑Fri Jan 28, 2022 3:26 pm I have stuff on order for months from USA ,pushrods, valves,TFS cylinder heads, like I said earlier I had shelf pistons on order for 6 months.
Thing is, and this was from other conversations, is that the replacement piston is heavy at 700+ with pin. Just like what's in there now and the notion is that an upgrade to a lighter piston, like the Wiseco, wouldn't be a bad move. Then again, as I said, I've beat the hell out of these hypereutectics for tens of thousands of miles without incident.
As for a tight budget, not so much really. But I don't want to spend where it isn't necessary.
Case in point is a rebalance for the piston we end up with. Looks like $750 (CDN) for any replacement (as spec'd) whether it's the forged Wisecos or the cast Speed Pro. Or the DSS for that matter. Two come with added machining costs, the other should be a straightforward swap.
Save a little here, spend a little there. Probably more spend down the road than save up front.
Here's a question. Scenario A: Replace with equal weight, which is heavy but no rebalance or scenario B: Go for the work involved with a lighter piston. Might be 100-150 grams in the difference.
Where's the benefit if I'm not taking this engine to the extremes? The target is peak HP RPM at or less than 6000. That's not a lot of revs by SBC standards and in a drag racing context, not a lot of time at peak. (Might sneak a road race in there though).
Kevin
I'm leaning that way for more than that reason but that is a valid point.rustbucket79 wrote: ↑Thu Jan 27, 2022 11:43 pm Wait on the Wiseco’s, that’s criminal what FM charges for those pistons considering you still have to buy rings.
Kevin
If the budget is not so tight… Is a stroker crank with matched pistons and rods available for quick delivery?skinny z wrote: ↑Sat Jan 29, 2022 12:04 pmNow there's an interesting option. I'll discuss that with the shop later today. Apparently, they have a lead of a tic for tac replacement piston but, and this is where this started, has a 5/64th's ring. I'll throw that Total Seal idea out there and see what comes of it.ProPower engines wrote: ↑Sat Jan 29, 2022 11:31 amJust thought I would ad that Total Seal has a narrow ring set available to be used in the wider grooves as well.skinny z wrote: ↑Fri Jan 28, 2022 11:28 pm
That’s what my machinist convinced me to do on my small ford. Mike Jones reground my cam to suit my smallish heads… I went with a smaller nitrous shot, that rarely gets used… Overall very pleased…
Don’t forget… winter won’t last forever…it will be tough standing on the sideline watching…with a few more dollars in your pocket…if your parts don’t arrive in time. Just a thought.
If you go with the Wiseco pistons do your self a favor and get them without rings.
If I remembers correctly they come with a 1.2 mm 1-2 ring and 3mm-4mm oil ring.
The top ring is a nitrided steel and the rings that come with the pistons are a narrower radial depth then required.
They were made by Hastings for Wiseco prior to the corporate but out by RWB group. I do not know if they still supply them or not but I had issues with their new rings and switched to Total Seal to solve the issue. And if you chat with Keith and the boys at TS they will advise you the same thing with the radial depth issue.
Personally I would go with the DDS piston option. They are about the same lead time and offer more choices like coated skirts lateral gas ports etc at much more competitive prices. Being a RWB/Wiseco dealer out here on the west coast I have been using the DSS stuff in their place because of time and options.
